What gear ratio with blown Hemi, 727, 30 inch tire? #1235438
05/18/12 02:02 PM
05/18/12 02:02 PM
Mopar Lane,Mississippi
67HEMI Offline OP
67HEMI  Offline OP
If I ever get all my parts it is "supposed" to make around 1100 horsepower in the Coronet with about 3650 pounds and 30 inch drag radials. It has a Dana and will be street driven 75% of the time and WFO the other 25%. Would a 3.55 put too much load on the driveline or would a 3.73 work better? It has a 4.10 in it now, I am leaning toward the 3.55.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: 67HEMI] #1235439
05/18/12 02:35 PM
05/18/12 02:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
All I can say is "DAMN" that`s gonna be a handfull either way.......
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: Thumperdart] #1235440
05/18/12 04:27 PM
05/18/12 04:27 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
4.10 BUT TALL TIRES HERE
home of the
Sox and Martin Hemi Duster
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: HEMIFRED] #1235441
05/18/12 05:10 PM
05/18/12 05:10 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
I run 4.10 with 31x16.5 Hoosier QTP's.
IMO the 3.55's will be too low.
What size conv are you using?
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: 67HEMI] #1235442
05/18/12 08:56 PM
05/18/12 08:56 PM
gregsdart Offline
gregsdart  Offline
With the 3.55 and guessing about 900 ft lbs torque, the 3.55 with a 30 inch tire will have a ton of launch torque. Starting line ratio is 2.45 x 3.55 =8.70. Torque times 2 (converter multiplication) times SLR is 15660 ft lbs at the axle, and less at the tire ,12528. Take away 10 percent for driveline loss, you still have 11275 lbs of thrust. Divide by the car weight, the thrust in Gs comes out to 3.09. I doubt you will be able to dead hook the car with a 3.55 gear. Maybe a 2.76, but Danas don't come with those . So the 3.55 is your best bet for now. Tub it, put a 15 x 33 x 15 slick on it and some wheeliebars and ride the back tires to the 60 foot mark!
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: gregsdart] #1235443
05/19/12 10:32 AM
05/19/12 10:32 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I run a similar combo and use the 4:10's.My street tire is 16.5 x 31.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: 67HEMI] #1235444
05/20/12 09:35 PM
05/20/12 09:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i am putting in my 3.73 back ing that i started with 12yrs ago but my vert was made for it.at 136 mph i trap at 6500 rpm with 4.10 and 28 tire.[slick,3900#w/driver]
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: Thumperdart] #1235445
05/21/12 05:48 PM
05/21/12 05:48 PM
67HEMI Offline OP
67HEMI  Offline OP
I want to "need" a depends diaper when I drive it
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: Blown 68 R/T] #1235446
05/21/12 05:50 PM
05/21/12 05:50 PM
67HEMI Offline OP
67HEMI  Offline OP
Somewhere around 4200, depends on camshaft.
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: gregsdart] #1235447
05/21/12 05:55 PM
05/21/12 05:55 PM
67HEMI Offline OP
67HEMI  Offline OP
Thanks for the calculations,tubbing has crossed my mind after this past weekend. I saw 2) 55 chevies with 20inch wheels 15" wide on the rear and both cars were about 6 inches off of the ground.
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: hemi-itis] #1235448
05/21/12 05:56 PM
05/21/12 05:56 PM
67HEMI Offline OP
67HEMI  Offline OP
Did you ever get those SV-1s on your setup?
Re: What gear ratio with blown Hemi, 727, 30 inch tire? [Re: 67HEMI] #1235449
05/21/12 05:57 PM
05/21/12 05:57 PM
I treid 4.30 to 3.73 in my street car, 700 + HP N/A, no differences in at the track performance other than it seem to be in high gear a lot longer with the 3.73.That was with the 8 3/4 that i bent the snout out of three years ago now (It has dana 60 truck housing with 4.10 in it now ) That was with the M/T ET Street Radials 315x60x15 tires at 128.6 MPH with all four sets of gears I would put the 3.55 in it, more pinion tooth contact to the ring gear teeth
