Front End Alignment Question #1235157
05/17/12 10:13 PM
05/17/12 10:13 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
I had lowered the torsion bars. No problems. Had VW Bug tires radial on the front.
Changed tires only. Same wheels.
I wanted to match my M/T Sportsman rears.
So I bought these in '09 Bias Ply.
http://www.summitracing.com/parts/MTT-1574/
Lowered T-Bars more since tires are shorter.
Ever since the wheel wants to pull to the left. Quite a bit. I have switched wheels & tires from DS to PS. No Difference.
Left side caliper is not Dragging. Wheel bearing are fine. Local alignment shops say it won't fit on their lift. 1 shop said it would work but they can't attach the rear alignment jig and rotate it because of tire to limited quarter panel clearence.
What could have changed?
Toe
Caster/Camber
Help!
Re: Front End Alignment Question [Re: Moe] #1235158
05/17/12 10:32 PM
05/17/12 10:32 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Caster/Camber
this
It's Swifty! Swifty, you toad sucker!
Re: Front End Alignment Question [Re: zrxkawboy] #1235159
05/17/12 11:00 PM
05/17/12 11:00 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
everything changed. camber caster and toe.get it aligned
Re: Front End Alignment Question [Re: moretoys] #1235160
05/18/12 01:37 AM
05/18/12 01:37 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Down to just a blue car now.
Re: Front End Alignment Question [Re: 68HemiB] #1235161
05/18/12 05:20 PM
05/18/12 05:20 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
I cannot find anybody locally that will do just a front end alignment.
Re: Front End Alignment Question [Re: Moe] #1235162
05/18/12 05:27 PM
05/18/12 05:27 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Could you clarify that?... They want to sell you tires too? Or only do what they call a 4 wheel alignment? Or?...
Is you car tubbed or something that they can't get the fixture onto your rear rims without hitting the quarter panel? Could you post pics of showing your rear tires?
Maybe ask for Connecticut people that know of a good alignment shop friendly with older cars.
Re: Front End Alignment Question [Re: autoxcuda] #1235163
05/18/12 05:47 PM
05/18/12 05:47 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
The car is tubbed. ¼ panel lip rolled. This is the problem. They say they can't the fixture on.
Re: Front End Alignment Question [Re: Moe] #1235164
05/18/12 05:57 PM
05/18/12 05:57 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Then buy some tools and start doing your own...
Re: Front End Alignment Question [Re: Moe] #1235165
05/18/12 10:20 PM
05/18/12 10:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So is it a fixture like this one? Is it hitting the top of the quarter panel lip?
I would think Hunter would make some extension for the rim clamp tips. That would bring out the fixture from the quarter panel.
Re: Front End Alignment Question [Re: autoxcuda] #1235166
05/18/12 10:25 PM
05/18/12 10:25 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's a Hunter fixture tool I found on thier website that doesn't use the tire/rim.
Maybe you can contact Hunter and find if they know of a shop they have sold this "Wheel Off" fixture to in your area.
I would think/hope Hunter would be glad to help because that would justify a customer's purchase of that alignment accessory. I bet it's not cheap!
