I had lowered the torsion bars. No problems. Had VW Bug tires radial on the front.
Changed tires
only. Same wheels.
I wanted to match my M/T Sportsman rears.
So I bought these in '09 Bias Ply.
http://www.summitracing.com/parts/MTT-1574/Lowered T-Bars more since tires are shorter.
Ever since the wheel wants to pull to the left. Quite a bit. I have switched wheels & tires from DS to PS. No Difference.
Left side caliper is
not Dragging. Wheel bearing are fine. Local alignment shops say it won't fit on their lift. 1 shop said it would work but they can't attach the rear alignment jig and rotate it because of tire to limited quarter panel clearence.
What could have changed?
Toe
Caster/Camber
Help!
