Carter carb is hard to start - hot weather related? #1234907
05/17/12 01:09 PM
05/17/12 01:09 PM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
Well After switching from a holley carb to the carter carb, I'm having some problems starting the motor. It seems to be hard after a drive and sitting for a few mins to 45 mins. Is this a the dreaded heat soak or vapor lock I heard about.
I never had a problem with the holley, the carb runs great other than the hard starting.
At first I thought it had flooded, but while cranking the motor if I pump the gas it will start - any ideas
Re: Carter carb is hard to start - hot weather related? [Re: 67MIke] #1234908
05/17/12 01:29 PM
05/17/12 01:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's the fuel combined with the carbs design .
Why did you swap out the holley ?
Re: Carter carb is hard to start - hot weather related? [Re: 67MIke] #1234909
05/17/12 02:10 PM
05/17/12 02:10 PM
Central New York
bfury Offline
bfury  Offline
Central New York
If you are using fuel with ethanol it seems to boil or vapor after shutdown. If you have the electric choke, try adjusting that. On my 2 cars I have to hit the gas once and then it starts fine. I love the Carters/Eddy carbs, no leaks and ez adjustments.
No Stock
Re: Carter carb is hard to start - hot weather related? [Re: bfury] #1234910
05/17/12 02:43 PM
05/17/12 02:43 PM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
Thanks for the help. John I was running a 750 Holley which I think is a little big. Thought I would try the carter
Re: Carter carb is hard to start - hot weather related? [Re: 67MIke] #1234911
05/17/12 03:15 PM
05/17/12 03:15 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
do you have any sort of phenolic spacer?
They really work wonders on the Carter and AFB design carbs.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Carter carb is hard to start - hot weather related? [Re: bfury] #1234912
05/17/12 06:39 PM
05/17/12 06:39 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I just removed the carter from my super bee for that reason. Pain to get started after it's warm and shut down for a spell. Put a 750 Quick fuel runs super and no more hard start after shut down. My GTX has a TQ that does the same thing. I may switch that to a quick fuel also.
