Re: best battery?
[Re: Challenger 1]
#1234563
05/16/12 08:03 PM
05/16/12 08:03 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
Had an Optima 780cca in three cars....2 of them died prematurely. I brought one back to life using a light bulb trick....then it died a month later without a rebirth. I have a 540cca Delco and it spins the mini starter just fine., Never had a problem with it 3 years.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: best battery?
[Re: ramman5600]
#1234567
05/17/12 12:53 AM
05/17/12 12:53 AM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
Anyone use Odyssey Brand AGM?
i bought Odyssey VRLA for my tractor this spring.
So far so good...only been 2 months though
Re: best battery?
[Re: 70VcodeCoronetRT]
#1234569
05/17/12 08:06 PM
05/17/12 08:06 PM
Posts: 5,894 Florida
Locomotion
I put an Odyssey 1500 in the trunk of my race car a couple of years ago. I run a 50 amp alternator as required by the rules, but I charge between rounds during cooling anyway because of the electric fan and water pump. I liked it enough to buy pair of Die-Hard Platinum batteries for my 2004 Dodge diesel dually because they are manufactured by Odyssey, just relabeled - and less expensive!
I used Optima Red and Blue before with good luck, but now have the Optima as my auxilary trailer battery.
Re: best battery?
[Re: ramman5600]
#1234571
05/19/12 09:46 AM
05/19/12 09:46 AM
Locomotion
Any cross reference of links that shows the Odyssey compared to DieHard?
I don't know of an actual # cross-reference chart, but the specs and casings are the same, just different colors. Sears seems to have the most popular versions in their Platinum line, not as many variations as the Odyssey labeled versions.
Re: best battery?
[Re: Locomotion]
#1234572
05/19/12 09:57 AM
05/19/12 09:57 AM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Being a GM sercive manager/tech, we deal in delco batterys. I can tell ya that they have really fallen off the deep end. This last winter we literally warrentied EVERY delco battery we sold. and 3 of them took 3 tries to get a decent one for the customer.
embarrassing, hell yes. Try keeping customers that way. Didnt happen. We had to give a few their money back, and havent seen them since.
The Delco rep who is a jackass came in every month and gave us grief every time till finally I took a battery, just a random battery he dropped of to us, took it over to a truck we were fixing the brakes on, and it wouldnt start the truck, just a fast click, click,click, then I tested it with our tester and his off his truck, 0cca, and 8 volts or something like that.
So from now on I tend to tell the good customer that still come in to us to let us sell them a John Deere battery. THose things are awesome.
The one in my dads van has been in there since 2004, and its still jsut as good as the day he bought it.
Re: best battery?
[Re: ramman5600]
#1234576
05/19/12 04:06 PM
05/19/12 04:06 PM
Locomotion
Checking the specs between the same series batteries showed the same numbers weight, amps, etc. Cases are the same, just a different color. While it is possible there may be some differences, several other people on different forums observed the same thing. Sears Platinum Odyssey Can't explain the listed 4 lbs difference. But I wouldn't call it a "deal breaker".
