Re: removing brake drum on a 64 dodge?
[Re: TooMany62s]
#123436
09/20/08 09:32 AM
09/20/08 09:32 AM
The dreaded tapered axle drum puller.....
Exactly right, and the ONLY tool to use. If you have any friends with "early" Fords, IHC shouts, Jeeps, Most AMC's, and a few other '50's cars or pickups, one of them might just have them.
[Re: black64]
#123438
09/20/08 04:23 PM
09/20/08 04:23 PM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
Ive yet to see any parts store that has the correct puller for them.I have one in the garage and the rear brakes arent that bad to do once you do them.Just dont use a jaw puller or you will have instant junk for drums.I bought a 61 that some moron did that too.It was a 1 owner no rust low miles super clean car.Guy couldnt figure out why after the Mechanic he had that tore the drums off it would shake so bad the pedal jumped.I found some good drums at a local yard and cut them anddd it was fine.Rocky
Chrysler Firepower
[Re: therocks]
#123439
09/20/08 07:32 PM
09/20/08 07:32 PM
Posts: 308 michigan
black64
michigan
The puller shown is a sears hub puller and it will work.
[Re: black64]
#123440
09/20/08 09:36 PM
09/20/08 09:36 PM
therocks
Niles , Ohio
It might work unless they are on real good.Id look on Ebay and find an old SnapOn or Mac.I bought mine there for 30 bucks.Had one of the newer one and it shattered after 2 pulls.Rocky
Chrysler Firepower
[Re: marks69]
#123442
10/19/08 05:14 PM
10/19/08 05:14 PM
Posts: 3,884 Oregon
hooziewhatsit
bump-aroonie I have a 72 pickup, W200. I also want to check my front brakes. Do I need to find the same puller to get the hub off? My FSM is lacking in this area, lol. Just want to make sure before I break something Thanks, -Dave Edit: Nevermind, I figured it out. For future reference, once you have the six 9/16" bolts out, and the hub-lock assembly off, there is another 1.5" spacer you need to knock off with a hammer. Then you'll have a snap ring, and the nuts/washers hold the bearing assembly in.
