68 rally dash frame, Bee/Charger the same?
#1233870
05/15/12 03:33 PM
05/15/12 03:33 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
I need a non-air rally dash frame for a 68 Superbee.. what years and models can i look for? Does a 69 Charger use the same frame?
Can i use a air cond frame for a non-air car? are they the same? Will the end plates work? I need everything to look 100% correct. Thanks
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
Re: 68 rally dash frame, Bee/Charger the same?
[Re: 70gtx440dana]
#1233873
05/15/12 04:20 PM
05/15/12 04:20 PM
No difference in a 68 or 69 rally dash frame. Either one will work on a 68. A non a/c frame would be better. If you use an a/c frame, you may have to do some metal fab work on the lower edges to omit the vent holes.
[Re: 6bblgt]
#1233875
05/15/12 06:06 PM
05/15/12 06:06 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
IIRC the ignition switch changed between '68 & '69 and the frame changed also.
I don't think there is a pop in insert for the different size ignition switch so it would be a 1 year only frame for each year 68 , 69 and 70.
the dashpad change for 69 on the upper pad was just a shape change from pointed to flat across the edge facing the driver , stud location I am 99.9% sure didn't change.
[Re: gtx6970]
#1233878
05/16/12 09:04 AM
05/16/12 09:04 AM
Posts: 3,378 KY USA
mopargem
KY USA
also 69 mounting tab for fuse block location is different
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#1233879
05/16/12 06:14 PM
05/16/12 06:14 PM
DaveDudek
N of Detroit
