Re: try to win or go fast? [Re: Mr.Yuck] #1233677
05/15/12 10:08 PM
05/15/12 10:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being that you shouldnt run faster than 11.50... I
would cut some wood blocks of assorted thickneses to
tape to the bottom of the gas pedal... and set it up
for 11.45 or so then dial 11.50 and pedal it
Re: try to win or go fast? [Re: MR_P_BODY] #1233678
05/16/12 09:57 AM
05/16/12 09:57 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
yeah I was thinking of taking some timing out, or shifting at 5800, or something else to slow it down. I'd like to run it hard 3/4 track and lift, but that'd be hard to judge and be consistant. The wood would (that's funny) be a decent and quick way to do it.
Re: try to win or go fast? [Re: Mr.Yuck] #1233679
05/16/12 01:14 PM
05/16/12 01:14 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Don't worry about it. Run it all out. It's going to be so hot and humid you'll probably be 3 tenths off anyway.
Re: try to win or go fast? [Re: pinkduster] #1233680
05/16/12 01:39 PM
05/16/12 01:39 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
it ALWAYS is..
high 81° | low 60° Mostly Sunny Hum.: 55% Precip.: 10% Wind: NNE at
5 mph
Re: try to win or go fast? [Re: Mr.Yuck] #1233681
05/16/12 05:56 PM
05/16/12 05:56 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
I am lucky to win 27 times in mostly Chevy and Ford races.The way I look at it is not set it up all out I use the small tires I could get away with,Eddy RPM,small street roller cam 308",4000 stall,511"er shift@5700 runs 6.40s 1/8 with 1.40 to 1.42 with 60ft with 456 gears. 850DPer/SD intake helps reaction time.I will try an 1150 holley& a Team G.~~ Bent
Section 8 Racing We are nuts about racing.
Re: try to win or go fast? [Re: Mr.Yuck] #1233682
05/16/12 06:23 PM
05/16/12 06:23 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
and we also won a free inter in a $1000 run-for-the-money dead on pass 6.7101pass on a 6.71 to try in a $100,000 race.
Re: try to win or go fast? [Re: jamesc] #1233683
05/16/12 09:56 PM
05/16/12 09:56 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
i would think most tracks (if they're paying attention) are going to boot you if you run under 11.5 anyhow so that being the case i would try to set it up to run 11.50s
Mason Dixon will adjust your dial right before you stage during first round if they see insufficient safety gear for the dial.
Am I supposed to say "don't ask me how I know" now?
This post is available in double vision where drunk.
Re: try to win or go fast? [Re: bwdst6] #1233684
05/17/12 05:47 PM
05/17/12 05:47 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Boy that would pi$$ you off !
Re: try to win or go fast? [Re: 383man] #1233685
05/17/12 09:34 PM
05/17/12 09:34 PM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
I always run the car flat out and see how fast it is running that day. Then I dail right at my fastest et and try to cut a good lite and win. My car is usually pretty consisdent and I figure it will run within a few hundreths of my best et. So if I cut a bad lite I will loose anyway. But if I have them covered in eliminations I will hit the brake and slow it down. Good luck as I want to go but dont know if I can make it. Ron
I'm with Ron, I've always tryed to run it flat out the same every round.(of course I'm no track champion, I've found dozens of ways to loose)Dave
Re: try to win or go fast? [Re: bwdst6] #1233686
05/18/12 11:17 AM
05/18/12 11:17 AM
Baltimore,MD
lowbudget Offline
mopar addict
lowbudget  Offline
mopar addict
Baltimore,MD
Yes! Ive quoted this for truth lol...had it happen to me there too
Re: try to win or go fast? [Re: lowbudget] #1233687
05/18/12 01:19 PM
05/18/12 01:19 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Go for the swag and cash and save your best time for the time onlys after you win or get knocked out.
