HEADER SIZE #1233609
05/15/12 07:44 AM
05/15/12 07:44 AM
North Carolina
CALSDART Offline OP
CALSDART  Offline OP
North Carolina
I need some advice on the correct header size for an engine that has been dyno'd at 800 hp. Current headers on this engine are 2 inch. This is a drag car.
Calvin Thompson
Re: HEADER SIZE [Re: CALSDART] #1233610
05/15/12 10:01 AM
05/15/12 10:01 AM
NC
440Jim Offline
440Jim  Offline
NC
What size engine (CID)?
What is the peak torque and horsepower RPM points?
Converter stall RPM?
Car weight?
Primary length and diameter are important. I love the 2-1/8 x 32" long headers on my 511 CID (~730-750 hp). 9.3x at 3225 lbs, 5500 stall, shift at 6700.
Re: HEADER SIZE [Re: CALSDART] #1233611
05/15/12 12:18 PM
05/15/12 12:18 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
This'll get you in the ball park.
http://www.wallaceracing.com/header_length.php
Re: HEADER SIZE [Re: CALSDART] #1233612
05/15/12 12:27 PM
05/15/12 12:27 PM
2.25 primary, better with a step 2.125 to 2.25 or bigger on both, and 4.0 inch collector, a good merge collector of the proper size is worth some power also
Re: HEADER SIZE [Re: tubtar] #1233613
05/15/12 04:01 PM
05/15/12 04:01 PM
NC
440Jim Offline
440Jim  Offline
NC
Interesting. I don't have any dyno data on my engine so I guessed 107% Volumetric effeciency:
4.250 stroke, 4.375 bore
90 BBDC exh valve opening at 0.020" adv, 320 adv duration
Shift light is set to 6700 rpm.
6700 rpm, 107% VE
Your Primary Tube Length is 35.47
Your Primary Tube Diameter is 2.06 inches
Your Collector Diameter is 3.61 inches
7000 rpm, 107% VE
Your Primary Tube Length is 33.79
Your Primary Tube Diameter is 2.11 inches
Your Collector Diameter is 3.70 inches
I don't know if that calc is for OD or ID (guess ID). My headers are 2-1/8 OD and 0.060 wall, so that is 2.005" ID.
Re: HEADER SIZE [Re: 440Jim] #1233614
05/15/12 04:21 PM
05/15/12 04:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
ALL tubing is OD
Re: HEADER SIZE [Re: MR_P_BODY] #1233615
05/16/12 09:59 AM
05/16/12 09:59 AM
NC
440Jim Offline
440Jim  Offline
NC
ALL tubing is OD
Yes, but all flow calculations are ID. The Wallace web site does not say if they adjusted the flow calc for an assumed wall thickness (0.030, 0.040, 0.050, 0.060, etc.)
Re: HEADER SIZE [Re: CALSDART] #1233616
05/16/12 09:38 PM
05/16/12 09:38 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
My 500in Indy 440-1 motor dynoed at 820hp 710tq and loved my 20 yr old Hooker Super Comps 2in staight 34length and 3 1/2 collector.
The little old lady from Pasadena is back!
