Main/Rod Bearing Clearances #1233294
05/14/12 05:27 PM
05/14/12 05:27 PM
Out West
408strokerdart Offline OP
Out West
Looking for information on bearing clearances that you have ran in your race engines. Please keep the information related to race only applications since I think it varies to much from street stuff to cross over.
What was the combo (Aluminum rod/Steel Rod, Aluminum Main Caps, etc.)? Journal sizes? Also, successes or failures on oil pressure. Half grooved mains, 3/4 grooved mains, etc..??
I know there are guidelines of so much clearance/inch of journal, but I am looking for real world experiences. I'm not sure if I am right or wrong, but I would assume that you could get away with slighlty tighter tolerances on an aluminum rod or aluminum block or aluminum main engine (due to thermal expansion differences), but I don't know that for sure.
Re: Main/Rod Bearing Clearances [Re: 408strokerdart] #1233295
05/14/12 06:12 PM
05/14/12 06:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
Iron block,BB steel cranskhaft and steelrods, .003+ on the mains and at least .0025 on the rods. More for aluminum rods (.003+) or blocks(.0035+) on both I like and use the full groove main bearings, Federal Mogul narrow grooves on the iron blocks and the Clevite 426 Hemi wide race main bearings on the aluminum blocks with steel caps
Re: Main/Rod Bearing Clearances [Re: 408strokerdart] #1233296
05/14/12 06:30 PM
05/14/12 06:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Jason Pettis and I recentlly had this very same conversation and he said he actually saw less wear and could actually re-use the bearings in 6-second big motors by going as loose as .005...........
Re: Main/Rod Bearing Clearances [Re: 408strokerdart] #1233297
05/14/12 06:43 PM
05/14/12 06:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use .003 on mains and rods... steel H-beam and chevy
rod journals... I never go below .0025... 1/2 groove
bearings
Re: Main/Rod Bearing Clearances [Re: Thumperdart] #1233298
05/15/12 12:20 AM
05/15/12 12:20 AM
Out West
Out West
Wow....that's alot of clearance!
Re: Main/Rod Bearing Clearances [Re: MR_P_BODY] #1233299
05/15/12 12:24 AM
05/15/12 12:24 AM
Out West
Out West
bearings
Any thoughts on aluminum rods? I sometimes see people add clearance for alum rods, but I would think it would be the other way. Any technical reason why?
Re: Main/Rod Bearing Clearances [Re: Cab_Burge] #1233300
05/15/12 12:28 AM
05/15/12 12:28 AM
Out West
Out West
Cab, I see it often but never see a reason why more clearance is required on aluminum rods. Can you add to this? Thanks.
Re: Main/Rod Bearing Clearances [Re: 408strokerdart] #1233301
05/15/12 12:30 AM
05/15/12 12:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
bearings
I owned a set of BB alum rods and I have heard that
it needs to be larger... it expands in all directions
so it would decrease the clearance also... I sold
those rods so I have never used any alum rods
Re: Main/Rod Bearing Clearances [Re: 408strokerdart] #1233302
05/15/12 12:52 AM
05/15/12 12:52 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
bearings
I believe these are alum. rod motors..........
Re: Main/Rod Bearing Clearances [Re: Thumperdart] #1233303
05/15/12 01:12 AM
05/15/12 01:12 AM
Middleton, ID
curleysracecars Offline
Middleton, ID
Aluminum rods grow slightly when hot, meaning the diameter of the big end gets smaller, tightening up on the crank. We run .004 in our 820" motor.
Kyle Curley
Re: Main/Rod Bearing Clearances [Re: Thumperdart] #1233304
05/15/12 01:16 AM
05/15/12 01:16 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Ive run about .002 but everything needs to be straight. I'd like to see .001 per inch of diameter. I've also heard of some big motors that run over .004 .
Re: Main/Rod Bearing Clearances [Re: DavidDean] #1233305
05/15/12 01:23 AM
05/15/12 01:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My brothers SB chevy we ran .006 on the rods BUT you
HAD to pre heat the oil before you could fire it...
that was some years back so I think the material is
alot better now... you can get way more than 300 passes
on a set now days
Re: Main/Rod Bearing Clearances [Re: MR_P_BODY] #1233306
05/15/12 02:48 AM
05/15/12 02:48 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Well i am in the .003-.0035 club myself .Aluminum rod and block BB's. The 99 hemi is atad more and was built by that Pettis guy
Re: Main/Rod Bearing Clearances [Re: curleysracecars] #1233307
05/15/12 02:59 AM
05/15/12 02:59 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
No offense, but that's wrong. The bore gets bigger. But a drag motor needs more clearance because the oil never really warms up. Thick oil means lots of drag and the potential for spun bearings. I urge you to test me on this. When a rod gets resized I always went over the big number. Once it cooled down, it shrunk to below the big number.
Re: Main/Rod Bearing Clearances [Re: 408strokerdart] #1233308
05/15/12 10:54 AM
05/15/12 10:54 AM
Az
Crizila Offline
Crizila  Offline
Az
My last two ( actually 3 - one was a chevy ) stroked small blocks I have built were tight. .002 on both rods and mains ( all steel ). Along with that I have been running a low viscosity full synthetic oil. Not sure if it is better or worse than going in the other direction? Haven't spun anything. I see less pressure swings with oil temp changes. Also think it helps in the windage / oil control area and makes better use of the newer quality oils that are out there these days. . I'm far from an expert engine builder and don't do it for a living, so - - - - - .
Fastest 300
Re: Main/Rod Bearing Clearances [Re: Crizila] #1233309
05/15/12 11:08 AM
05/15/12 11:08 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I set up clearances by what oil is to be used. In the class engines that run RP No. 9(0/10) or thinner are set at .0015. Street/bracket engines .002-.003. using a 10/30 type oil. I don't mess with real big engines so don't know what I would do there.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Main/Rod Bearing Clearances [Re: 408strokerdart] #1233310
05/15/12 12:16 PM
05/15/12 12:16 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
IIRC, the Joe Gibbs oil web site has some tech info on viscosity vs. application, clearances & expected oil temps.
Re: Main/Rod Bearing Clearances [Re: sixpackbee] #1233311
05/15/12 12:27 PM
05/15/12 12:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Yes, I should have qualified my last post by saying the last 3 engines I have built are in the 500HP range.
Fastest 300
