Main/Rod Bearing Clearances
#1233294
05/14/12 05:27 PM
05/14/12 05:27 PM
Posts: 3,456 Out West
408strokerdart
Out West
Looking for information on bearing clearances that you have ran in your race engines. Please keep the information related to race only applications since I think it varies to much from street stuff to cross over.
What was the combo (Aluminum rod/Steel Rod, Aluminum Main Caps, etc.)? Journal sizes? Also, successes or failures on oil pressure. Half grooved mains, 3/4 grooved mains, etc..??
I know there are guidelines of so much clearance/inch of journal, but I am looking for real world experiences. I'm not sure if I am right or wrong, but I would assume that you could get away with slighlty tighter tolerances on an aluminum rod or aluminum block or aluminum main engine (due to thermal expansion differences), but I don't know that for sure.
Re: Main/Rod Bearing Clearances
[Re: 408strokerdart]
#1233297
05/14/12 06:43 PM
05/14/12 06:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use .003 on mains and rods... steel H-beam and chevy rod journals... I never go below .0025... 1/2 groove bearings
[Re: Thumperdart]
#1233298
05/15/12 12:20 AM
05/15/12 12:20 AM
408strokerdart
Out West
Jason Pettis and I recentlly had this very same conversation and he said he actually saw less wear and could actually re-use the bearings in 6-second big motors by going as loose as .005...........
Wow....that's alot of clearance!
[Re: MR_P_BODY]
#1233299
05/15/12 12:24 AM
05/15/12 12:24 AM
408strokerdart
Out West
Any thoughts on aluminum rods? I sometimes see people add clearance for alum rods, but I would think it would be the other way. Any technical reason why?
[Re: Cab_Burge]
#1233300
05/15/12 12:28 AM
05/15/12 12:28 AM
408strokerdart
Out West
Iron block,BB steel cranskhaft and steelrods, .003+ on the mains and at least .0025 on the rods. More for aluminum rods (.003+) or blocks(.0035+) on both I like and use the full groove main bearings, Federal Mogul narrow grooves on the iron blocks and the Clevite 426 Hemi wide race main bearings on the aluminum blocks with steel caps
Cab, I see it often but never see a reason why more clearance is required on aluminum rods. Can you add to this? Thanks.
#1233301
05/15/12 12:30 AM
05/15/12 12:30 AM
MR_P_BODY
I owned a set of BB alum rods and I have heard that it needs to be larger... it expands in all directions so it would decrease the clearance also... I sold those rods so I have never used any alum rods
[Re: Thumperdart]
#1233303
05/15/12 01:12 AM
05/15/12 01:12 AM
Posts: 186 Middleton, ID
curleysracecars
Middleton, ID
Aluminum rods grow slightly when hot, meaning the diameter of the big end gets smaller, tightening up on the crank. We run .004 in our 820" motor.
Kyle Curley
[Re: DavidDean]
#1233305
05/15/12 01:23 AM
05/15/12 01:23 AM
MR_P_BODY
My brothers SB chevy we ran .006 on the rods BUT you HAD to pre heat the oil before you could fire it... that was some years back so I think the material is alot better now... you can get way more than 300 passes on a set now days
[Re: curleysracecars]
#1233307
05/15/12 02:59 AM
05/15/12 02:59 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
No offense, but that's wrong. The bore gets bigger. But a drag motor needs more clearance because the oil never really warms up. Thick oil means lots of drag and the potential for spun bearings. I urge you to test me on this. When a rod gets resized I always went over the big number. Once it cooled down, it shrunk to below the big number.
#1233308
05/15/12 10:54 AM
05/15/12 10:54 AM
Posts: 7,506 Az
Crizila
Az
My last two ( actually 3 - one was a chevy ) stroked small blocks I have built were tight. .002 on both rods and mains ( all steel ). Along with that I have been running a low viscosity full synthetic oil. Not sure if it is better or worse than going in the other direction? Haven't spun anything. I see less pressure swings with oil temp changes. Also think it helps in the windage / oil control area and makes better use of the newer quality oils that are out there these days. . I'm far from an expert engine builder and don't do it for a living, so - - - - - .
Fastest 300
[Re: Crizila]
#1233309
05/15/12 11:08 AM
05/15/12 11:08 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
I set up clearances by what oil is to be used. In the class engines that run RP No. 9(0/10) or thinner are set at .0015. Street/bracket engines .002-.003. using a 10/30 type oil. I don't mess with real big engines so don't know what I would do there.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
