stock 1950 Plymouth front brake problem #1233170
05/14/12 08:07 AM
05/14/12 08:07 AM
livonia mi.
P
PSRacing1 Offline OP
P
livonia mi.
Well... We have a 1950 Plymouth 2 door wagon ( hot rod? ) just bought it ... We need help ..Problem #1 The front brake system is stock 1950 and the left front brake locks up when you touch the pedal ,I can't put my son on the road with this type of system problem , does anyone know if there is a front disc system that will replace the front drum, I have a pair of 70 Challenger disc brake assy complete but will it work? or can this be fixed until we find disc brakes to swap ? Contact Pat psroadster@aol.com or call 734 591 3781
Re: stock 1950 Plymouth front brake problem [Re: PSRacing1] #1233171
05/14/12 11:20 AM
05/14/12 11:20 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
1. you might want to remove your personal contact info.
2. There are a few different disc conversions on the market. None use the 70 challenger parts IIRC.
3. The stock drums require a special adjustment procedure that may resolve your problem. Check the P-15 D-24 website and the Imperial club website for more info on the OE brakes.
