correct driveshaft length 73 charger? #1232856
05/13/12 04:45 PM
05/13/12 04:45 PM
ontario canada kingston
aspenrt360 Offline OP
hey guy's anyone sure of the length? it is a smallblock with a 727 and an 8.75 diff. thanks
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: correct driveshaft length 73 charger? [Re: aspenrt360] #1232857
05/13/12 10:28 PM
05/13/12 10:28 PM
bump
Re: correct driveshaft length 73 charger? [Re: aspenrt360] #1232858
05/14/12 08:57 PM
05/14/12 08:57 PM
really? no one?
Re: correct driveshaft length 73 charger? [Re: aspenrt360] #1232859
05/14/12 09:28 PM
05/14/12 09:28 PM
Morningside, Long Island
scatcity Offline
scatcity  Offline
Do you have your Broadcast sheet ?
Re: correct driveshaft length 73 charger? [Re: scatcity] #1232860
05/15/12 05:27 PM
05/15/12 05:27 PM
well thanks for the help guy's? things sure have changed around here over the last ten years i will go elsewhere. cheers
Re: correct driveshaft length 73 charger? [Re: aspenrt360] #1232861
05/15/12 05:53 PM
05/15/12 05:53 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Do not have a challenger. Have a cuda. Different wheelbase. Probably not that many around, and they arent rolling of the assembly line.
How about measuring center to center ?
Re: correct driveshaft length 73 charger? [Re: aspenrt360] #1232862
05/15/12 06:18 PM
05/15/12 06:18 PM
scatcity Offline
scatcity  Offline
Things sure have changed over the years. If you do have your BS sheet, you can get your correct part # of your shaft from there and answer your own question. If you don't have your BS sheet, search the numerous ones available online and I'm sure you'll stumble on one with your engine / trans / rear end config and grab that part #. Here, this might help:
Re: correct driveshaft length 73 charger? [Re: scatcity] #1232863
05/15/12 06:20 PM
05/15/12 06:20 PM
scatcity Offline
scatcity  Offline
See attatchment:
Re: correct driveshaft length 73 charger? [Re: scatcity] #1232864
05/16/12 06:15 PM
05/16/12 06:15 PM
the build sheet for this car was gone long before i ever saw it, along with the engine and the trany! i have a 360 with a 727 in there now while i was at it i swapped out the 8.25 for a nice 8.75 i had so i have to get a d shaft now. i am going to go under it tonight an use a spare yolk to speck out the shaft. thanks though
