lunati roller #1232806
05/13/12 02:23 PM
05/13/12 02:23 PM
bentman Offline OP
bentman  Offline OP
part # 60412 thinking about going with this cam in a 408 motor. The car will have a 2500 stall 3.55 rearend.
Will this cam make alot of Tq early? I'm south of Houston so I need a A/C car what are yalls thoughts? this will be in a 73 RR
Re: lunati roller [Re: bentman] #1232807
05/13/12 02:43 PM
05/13/12 02:43 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
welcome to the board, this question might be better in the race forum or Q&A section
this forum is for older street rod stuff and less people come here. Ron...
Re: lunati roller [Re: bentman] #1232808
05/13/12 04:37 PM
05/13/12 04:37 PM
scratchnfotraction Offline
I run a 60710 lunati roller cam with comp 901-16 springs
FYI..comp 901-16 are a single with damper,drop on with stock seals and no machine work.
lunati springs are double with damper,need pc seals with machine work to go on the head.
been turning 6200 rpm with the comp springs,stock roller lifters/PR/rockers
no help on that cam in a 408 but you can save some bux on the spring if you go with the lunati roller cam.
Re: lunati roller [Re: scratchnfotraction] #1232809
05/13/12 08:54 PM
05/13/12 08:54 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
from what I see on their website 60412 is not a solid roller...
In my Indy headed 408 I run a 60434, but a bit steep for you...
I would suggest a 60431
Dan
