Replacement Brake linkage parts? #1232783
05/13/12 01:07 PM
05/13/12 01:07 PM
OK
David_Trimble Offline OP
OK
Who carries them? I've got worn out bushings in my brake pedal linkage. I've got dealer part numbers for them too FWIW. Wasn't there a website at one time where you could search Mopar dealers for parts? I don't have the link to it anymore and even Google doesn't seem to find it ....
Thanks!
David
'69 Dodge Charger R/T
Re: Replacement Brake linkage parts? [Re: David_Trimble] #1232784
05/14/12 09:35 AM
05/14/12 09:35 AM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
Are you talking about these white ones?
https://www.yearone.com/Catalog/CatalogSearch/24
Re: Replacement Brake linkage parts? [Re: superbeedave] #1232785
05/14/12 01:28 PM
05/14/12 01:28 PM
OK
OK
Hmm- the link didn't work but if you mean the white plastic bushings, no (I've managed to find those already anyway ) There are 2 metal bushings - one fits into the end of the brake booster and the other fits in the end of the brake pedal link that bolts to the linkage that connects the pedal to the booster. I know that sounds a bit vague- I can post a FSM drawing later today if it'll help....
Re: Replacement Brake linkage parts? [Re: David_Trimble] #1232786
05/14/12 06:47 PM
05/14/12 06:47 PM
OK
OK
Checked with the dealer today and other than the plastic bushings, none of the metal bushings are still available. Guess I'll have to find some used ones.....
