Can I swap out just one lifter?
#1232673
05/13/12 11:15 AM
05/13/12 11:15 AM
Posts: 5,893 Athens, Greece
Pyper70
Athens, Greece
I had put my RPM heads on about 2-3 weeks ago. I come to find out many of my lifters needed to be pumped up, while I had the valley pan out I had taken them apart, pumped em up with oil and popped em back in again. I had finished putting it together and a ticking noise was still there. I took it out for a spin hoping the lifter would pump up with the oil nice and hot, nothing...stick ticks. I took it out for a 3 hour drive....still ticks. Something is up with that lifter on the #6 Intake.
Can I replace the one lifter? Do I have to buy a new set? Do I have to get the same exact lifter because I don't remember which manufacturer they were. I know its 1.90" tall and it has the oiling ring about 1/4" all around where the oiling orifice is.
Will a Summit special work if its the same height?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Can I swap out just one lifter?
[Re: Pyper70]
#1232674
05/13/12 11:21 AM
05/13/12 11:21 AM
Posts: 1,261 ILL
mark7171
ILL
Sure. Iwoulduse the same brand though.
What is the spring pressure. That is why the lifters bleed down.
My space barbroke.
[Re: Pacnorthcuda]
#1232678
05/13/12 03:19 PM
05/13/12 03:19 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Yes you can do one lifter, NO it doesn't have to be the same brand! A lifter doesn't know what brand its neighbors are nor does it care. (I guess lifters are politically correct)
[Re: JohnRR]
#1232679
05/13/12 03:26 PM
05/13/12 03:26 PM
Pyper70
Athens, Greece
Yes you can change out one lifter , you have to do the normal break in procedure .
Man...really? I gotta run it for 20 minutes above 2500rpm...?
There's a reason for the lifter not working properly, take it all the way apart including the little poppit valve and spring on the bottom of the lifter cup, it is a one way valve that may have a tiny of trash or debris in it
I have taken it apart already, thats the weird part...popped the retainer out, pulled the valve with spring, cleaned it out with PJ-1 aerosol, ran the compressed air through it, took out the little recessed tip, cleaned that out and filled with it a little bit of oil. Put it all back together and bench bled it on the drill press.
[Re: Pyper70]
#1232680
05/13/12 03:34 PM
05/13/12 03:34 PM
Pyper70
Athens, Greece
Looking through the Summit website, if there pictures of lifters is anything like the actual product, looks like the Purple Shaft lifter from MP is the one I have.
[Re: Pacnorthcuda]
#1232681
05/13/12 05:45 PM
05/13/12 05:45 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
Not all lifters are the same , there is no rhyme nor reason for oil band placement and the pushrod cup could be potentially in a different spot .
[Re: JohnRR]
#1232682
05/13/12 05:52 PM
05/13/12 05:52 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Yep. True. And as long as the lifter itself does the job its made to do it does not have to match its neighbors.
[Re: Pyper70]
#1232684
05/13/12 09:40 PM
05/13/12 09:40 PM
Posts: 3,377 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I've recently dealt with BB lifters. Pay attention to the "seat height" as that will affect your preload and you don't want too much or too little. I have seen pics of the Mopar versions and they look like ONE version of the Sealed Power HT-976. I just put 16 of them in my engine -- but when I ordered them, 15 of them were 1 style and 1 of them was another. The 1 was the one that resembled the Mopar performance lifter-- the pushrod cup was completely smooth on the bottom. The other 15 had a small cutout there, not for oil to flow through though. See pic. I had to order some more and finally got to 16 of what I needed. All that was to say that they both had different seat heights, and some new Comp Cams lifters I have had an even different seat height. The HT-976 might be worth a try for you - you can get them at O'Reily auto parts usually a 1 day order by calling the store, and they are cheap. If you need 1, order 4 or 5 and you might see the 2 different versions, you can choose the one closest to the seat height of your old lifters.
