Nameplate restoration #1232667
05/13/12 09:37 AM
05/13/12 09:37 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline OP
Does anyone now of someone who restores/repaints nameplates? The plated finish is mint but the painted part leaves a lot to be desired. Fender, decklid and grille Challenger plates.
Thanks,
Bob
Re: Nameplate restoration [Re: radiatorman] #1232668
05/13/12 11:47 AM
05/13/12 11:47 AM
MD
floyd Offline
floyd  Offline
MD
I don't know of anyone that offers a resto service, but those emblems are pretty easy to do yourself if the plating is good.
Chem strip or lightly glass bead to remove the paint
mask the back of the emblem
Paint the entire front of the emblem black (I use testors "black chrome trim" paint sprayed with cheap air brush). I'm guessing you can find a rattle can of something similar.
Let the paint dry in the sun or bake it at low heat for a bit to cure.
Use a q-tip with laquer thinner to get the black off the face of the letters. Go easy on the thinner and blot the q-tip before applying and work one small area at a time.
Re: Nameplate restoration [Re: floyd] #1232669
05/14/12 09:36 AM
05/14/12 09:36 AM
I may try that. At this point probably my best option unless something else comes up.
Thanks,
Bob
Re: Nameplate restoration [Re: radiatorman] #1232670
05/14/12 10:56 AM
05/14/12 10:56 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Bob, give Mike Ross at BE/A a call and ask him, he may know.
MikeR
Re: Nameplate restoration [Re: radiatorman] #1232671
05/15/12 01:05 AM
05/15/12 01:05 AM
Franklinville,NJ
JeffsCustomPaint Offline
Franklinville,NJ
I restore emblems if you don't want to do it yourself.
as long a the chrome plating is good
here is stuff I have done for my car and now got some to restore for others after they seen my work
http://forum.grantorinosport.org/emblems-restored_topic5721.html
