removing axles #1232135
05/12/12 01:49 PM
05/12/12 01:49 PM
Franklin Furnace, OH
moparman1954 Offline OP
Whats the best way to remove the axles from a housing with green bearings? I'm changing the ring and pinion. Do you just pull them out like the stock adjustables?
Re: removing axles [Re: moparman1954] #1232136
05/12/12 02:02 PM
05/12/12 02:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep..............
Re: removing axles [Re: Thumperdart] #1232137
05/12/12 02:11 PM
05/12/12 02:11 PM
Just checking. My first green bearings car. Thanks!
Re: removing axles [Re: moparman1954] #1232138
05/12/12 02:39 PM
05/12/12 02:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Way easier than the old floating button in the rear to set end play.............
Re: removing axles [Re: moparman1954] #1232139
05/12/12 05:35 PM
05/12/12 05:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Turn the brake drum around backwards and put 3 lugnuts
on but keep them loose and use the drum as a slide hammer
of course after you take the 4 retaining nuts off
Re: removing axles [Re: MR_P_BODY] #1232140
05/12/12 07:26 PM
05/12/12 07:26 PM
Thats a good idea. Thanks
Re: removing axles [Re: moparman1954] #1232141
05/12/12 08:23 PM
05/12/12 08:23 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
One thing you will discover with the green bearings is that because the mounting flange doesnt float like the stockers it will be very difficult to get the flange to clear the metal strut that goes between the shoes at the top. The way to get them out then is just pull the backing plate off the studs with the axle so that you can get the flange to clear. No need to disconnect the brake line, as there is usually enough give in the hard brake line to do this without damaging anything. Just don't go nuts with it and you wont have any problem. Install the same way(with the backing plate off the studs).
MB
Re: removing axles [Re: HPMike] #1232142
05/12/12 09:13 PM
05/12/12 09:13 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Only first generation (Mopar Performance/RP-400) Green bearings have that problem.
Most Green bearings incorporate a snap ring and loose fitting flange (Moser/Strange/DoctorDiff/MO-400/ST-400).
Re: removing axles [Re: DoctorDiff] #1232143
05/12/12 09:16 PM
05/12/12 09:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Maybe that`s why mine just slide out like the tapered ones...........
Re: removing axles [Re: DoctorDiff] #1232144
05/13/12 10:58 PM
05/13/12 10:58 PM
Don't know if I have the early or late model bearings, but I know the axles don't feel like they will come out as easy as the stock bearings on my old car. Didn't notice any split rings, but had to go to work and did'nt work on it anymore. If it has split rings do they need removed to get the axles out?
Re: removing axles [Re: moparman1954] #1232145
05/14/12 06:33 PM
05/14/12 06:33 PM
Got the axles out today. Used the reversed drums trick and they came right out. Thanks Mr Pbody!
Re: removing axles [Re: moparman1954] #1232146
05/14/12 06:47 PM
05/14/12 06:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
