keisler guys, how is your exhaust clearence? #123201
09/19/08 02:47 PM
09/19/08 02:47 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
Hey, so does anyone have a keisler in their B-body with tti headers? How is your clearence? Mine sit way low now that I have the keisler in, and its in anoying. My headers are 2" off of the ground, a good 2" lower than they used to be. Anyone have any tricks to get them a little higher?
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: keisler guys, how is your exhaust clearence? [Re: 69charger440_6pa] #123202
09/19/08 09:06 PM
09/19/08 09:06 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
Did your kit come with a spacer for the trans mount to raise the trans? That should give you some additional clearence.
Re: keisler guys, how is your exhaust clearence? [Re: RTSE4ME] #123203
09/19/08 10:49 PM
09/19/08 10:49 PM
Oakley CA
Oakley CA
they sent me one after I asked for it, headers are still 2" off the ground
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: keisler guys, how is your exhaust clearence? [Re: 69charger440_6pa] #123204
09/20/08 01:45 AM
09/20/08 01:45 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Mine seemed low too , so I installed the trans using a large , dense piece of foam rubber around the shift tower and on top of trans , used a lift at work with a jack stand under the trans cross member , loosend the cross member bolts and droped the lift slowly and then tighted the bolts back up and seems much better now . Basicly reforming the trans tunnel a little and The cross member alot tighter to floor pan . Thers still enough clearance that nothing touches . Way better header clearance now , and no doubt better drive line angle .
Re: keisler guys, how is your exhaust clearence? [Re: 69charger440_6pa] #123205
09/20/08 09:40 AM
09/20/08 09:40 AM
MD
MD
How much clearence do have between the floorpan and collector flange? Also the TTI instructions should have the measurments for the engine position.
I have the same set-up as you RB with a 5 speed but in an e-body. I had to do some tweaking to get extra clearence since my car sits pretty low. The spacer helped quite a bit on my car. Don't understand how you could have the same clearence when you put the spacer in.
Re: keisler guys, how is your exhaust clearence? [Re: 69charger440_6pa] #123206
09/20/08 10:38 AM
09/20/08 10:38 AM
twin cities
dart_sportsatellite Offline
twin cities
I have plenty of clearance with mine, 69 Satellite, Keisler, tti with 3" pipes, schumacher mounts and a hemi.
Re: keisler guys, how is your exhaust clearence? [Re: RTSE4ME] #123207
09/20/08 01:42 PM
09/20/08 01:42 PM
Oakley CA
Oakley CA
the spacer helped, but not as much as I would have liked. My car bottoms out just pulling into the garage.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: keisler guys, how is your exhaust clearence? [Re: 69charger440_6pa] #123208
09/20/08 10:56 PM
09/20/08 10:56 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Hmm. I've got the Keisler and TTI's. Low but not that low. The squat changed a little with the aluminum bellhousing and removal of the stock exhaust manifolds and may have compensated. I angle speed bumps and get a mild scrape on rare occasion and only the flange. So far so good.
