Space in between strut rod bushing and K-frame? #1232011
05/12/12 02:24 AM
05/12/12 02:24 AM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
I noticed today that I have a couple millimeters of space in between my K-frame and the driver's side strut rod bushing:
Does this mean I just need to replace my strut rod bushings? Should I snug up the nut a little in the meantime? The passenger side doesn't have this same gap to it.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Space in between strut rod bushing and K-frame? [Re: Secret Chimp] #1232012
05/12/12 03:38 AM
05/12/12 03:38 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I would replace it if there is visible cracking. If it is intact and has some give to it, I'd snug up the nut and drive it. It may need to be REaligned though, since this rod locates the lower control arm.
