I noticed today that I have a couple millimeters of space in between my K-frame and the driver's side strut rod bushing: Does this mean I just need to replace my strut rod bushings? Should I snug up the nut a little in the meantime? The passenger side doesn't have this same gap to it.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
