Small block camshaft endplay #1231911
05/11/12 10:58 PM
05/11/12 10:58 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
With a hydraulic roller cam, what should the spec be? I thought it was .004"-.010", but not sure if I am mistaken. I am at .003" right now, wondering if it is too tight or not
So what do you guys think???
Re: Small block camshaft endplay [Re: mshred] #1231912
05/11/12 11:39 PM
05/11/12 11:39 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i have a solid roller with .004, ur good to go.
Re: Small block camshaft endplay [Re: rickraw] #1231913
05/12/12 12:47 AM
05/12/12 12:47 AM
SoCal
Brian Hafliger Offline
SoCal
Brian Hafliger
Re: Small block camshaft endplay [Re: Brian Hafliger] #1231914
05/12/12 01:28 AM
05/12/12 01:28 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
so that 1 thousandth is nothing to be concerned about?
Re: Small block camshaft endplay [Re: mshred] #1231915
05/12/12 08:51 AM
05/12/12 08:51 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
correct
Re: Small block camshaft endplay [Re: mshred] #1231916
05/12/12 01:55 PM
05/12/12 01:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Isky rollerized button touching stock cover(big block)not that it matters................
Re: Small block camshaft endplay [Re: Thumperdart] #1231917
05/12/12 10:46 PM
05/12/12 10:46 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Just for future reference, what is the acceptable spec minimum and maximum?
Re: Small block camshaft endplay [Re: mshred] #1231918
05/12/12 11:01 PM
05/12/12 11:01 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
out of the comp cams book, .004 to .010. u will be ok at .003.
