Front end alignment tools #1231845
05/11/12 09:14 PM
05/11/12 09:14 PM
templeton,ma
coro500net Offline OP
templeton,ma
Going to a local garage to get a alignment on my 65 Coronet,the owner said he is going to make me do all the adjustments.Just wondering if there is any special tools I may need to adjust the cam bolts.
Re: Front end alignment tools [Re: coro500net] #1231846
05/11/12 10:20 PM
05/11/12 10:20 PM
Andrewh Offline
Andrewh  Offline
nope. don't remember the size off hand, but just a regular socket or wrench.
one side loosens it, the other side does the adjusting.
I try to put them in so the adjust is in the wheel well for both.
Re: Front end alignment tools [Re: Andrewh] #1231847
05/12/12 12:26 PM
05/12/12 12:26 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
The adjusting cams are just a 3/4 inch wrench-socket. A half moon wrench makes things easier,but not necessary .depending on vehicle- 5/16 socket/nut driver too remove access plates.tie rods have a special adjusting tool.but if everything is somewhat fresh/new. a pair of channel pliers will work fine.
<<set tire pressure first
>>set ride height
>>set camber/caster making both sides equal is important. Radial tires about 0 deg camber.caster as positive you can.most likely/hopefully it will be in the 1.5-2 deg positive range.
set the steering wheel straight install holder,set toe. again equal side to side.
I have found this procedure to work well.: Set the rear cam all the way in/neg.(big fat end out)then fine tune the front adjustment to get the readings you want. Good luck
