05 Neon trans pan gasket #123181
09/19/08 01:26 PM
09/19/08 01:26 PM
North Pole,New York
formula_s Offline OP
North Pole,New York
Does a 05 Neon use a gasket or RTV on the transmission pan.
Re: 05 Neon trans pan gasket [Re: formula_s] #123182
09/19/08 01:29 PM
09/19/08 01:29 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
The dealer put RTV on my 03 when it was under warranty but it always seeped a little. I changed the filter and fluid and used a gasket and it is dry as a bone. mike
Re: 05 Neon trans pan gasket [Re: mopars4ever] #123183
09/19/08 01:57 PM
09/19/08 01:57 PM
North Pole,New York
North Pole,New York
Thanks, how many quarts to drop the pan?? That ATF+ 4 is $$$$.
Re: 05 Neon trans pan gasket [Re: formula_s] #123184
09/19/08 02:19 PM
09/19/08 02:19 PM
md
md
I don`t remember exactly since it was a few years ago. I think it was 3 or 4 but the dealer should be able to tell how many you need. How much is a quart now? I tried to look up the part number for the gasket from the dealer online look up and they don`t list one. I was pretty sure I got mine there. NAPA shows the gasket in cork and rubber. I used the rubber.
Re: 05 Neon trans pan gasket [Re: mopars4ever] #123185
09/19/08 02:43 PM
09/19/08 02:43 PM
North Pole,New York
North Pole,New York
Just got some from WalMart of all places, please don't hate me for that. $4.74 a qt.
Re: 05 Neon trans pan gasket [Re: formula_s] #123186
09/19/08 02:50 PM
09/19/08 02:50 PM
md
md
A lot cheaper than the dealer for sure. If your not sure how many to buy, get extra and take back what you don`t use. Measure what comes out and that should get you close. Don`t overfill.
