any Demon Carb. Guru's ? #1231722
05/11/12 01:51 PM
05/11/12 01:51 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
Hey Guy's, I am Wanting To Tune My 650 Mighty Demon That Is Mounted On Car. I would Like Get The Transition Slots Back To The Initial Set Up Of .020, But Do Not Want To Pull The Carb. Off If I Can Help It.Does Anyone Know How Many Turns Of The Idle Speed Screws when just Touching The Stops will Get Me To The .020 Transition Showing? Thanks, Tom
Re: any Demon Carb. Guru's ? [Re: Tom Fox] #1231723
05/12/12 07:20 AM
05/12/12 07:20 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Use the paper method,ppen throttle slide a peice of paper between lever and screw back off screw til you can just take out the paper,than open 1/2 to 1 turn . This will get you close you can tweek from there.Some cars like open more on frt than rear but I like to square it up.
