Draining Block #1231706
05/11/12 12:36 PM
05/11/12 12:36 PM
Indiana
litngetr Offline OP
litngetr  Offline OP
Indiana
I need to pull both heads on my 99 360 magnum. Passanger side drain plug on block is easy to get to. Will the anterfreeze on driver side be down enough to pull that head without a mess.
Re: Draining Block [Re: litngetr] #1231707
05/11/12 12:42 PM
05/11/12 12:42 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I recently pulled a head off a 318 Magnum. all I did was crack the lower radiator hose and let the system drain out. there was still a lot of water left in the block, but the coolant was low enough that I didn't fill the oil pan when the head came off.
however, the coolant was high enough that when I lifted up the front of the truck a few inches, water came out the back of the block, but it was the lower holes on the deck, and it dripped out to the floor.
after you do your head work, I would change the oil incase you do spill any water into the pan. Otherwise, have at it!
**Photobucket sucks**
