engine question #1231389
05/10/12 11:20 PM
05/10/12 11:20 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
What would cause a cold engine when you fire it runs rough but after it runs three or four minutes it smooth out? Sounds llike it is not hitting on all 8 when you first start. You can start it two hours later and will run fine on the start. It only does it when it sets for a few days. Thanks
Re: engine question [Re: 70 buzz] #1231390
05/10/12 11:23 PM
05/10/12 11:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Choke closed too tight.
Re: engine question [Re: stumpy] #1231391
05/10/12 11:29 PM
05/10/12 11:29 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: engine question [Re: 70 buzz] #1231392
05/11/12 10:18 AM
05/11/12 10:18 AM
The choke pulloff may not be operating
