74 RR radiator question #1231251
05/10/12 07:31 PM
05/10/12 07:31 PM
Grand Forks, ND
cougar_cat_25 Offline OP
Grand Forks, ND
Is the 26" radiator designed to fit in a 74 roadrunner? Mine measures closer to 28". Should I be looking at bracket fabrication to fit a narrower radiator or does someone manufacture a wider one?
Re: 74 RR radiator question [Re: cougar_cat_25] #1231252
05/10/12 07:52 PM
05/10/12 07:52 PM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
I used the Champion radiator sold by a member here for my 73 Roadrunner and 72 Challenger they both are the same radiators same part numbers and all.
Re: 74 RR radiator question [Re: GreenGlow] #1231253
05/10/12 09:05 PM
05/10/12 09:05 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
small block or big block? yes, the original 74 radiator is 28". You could probably get the 26 to work, if the bottom opening is on the right side. Most of the 26in ones I've seen have the bottom hose on the left( drivers) side
Re: 74 RR radiator question [Re: cougar_cat_25] #1231254
05/11/12 03:39 AM
05/11/12 03:39 AM
Grand Forks, ND
Grand Forks, ND
Green Glow, you are right on! Champion has exactly what I need. Passenger side inlet and outlet AND its the right width. Hopefully my floor jack stays away from this one
