"Felt" replacement in wing window frame '70 B-Body #1230775
05/10/12 12:53 AM
05/10/12 12:53 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Can you replace the "felt" in the back of the wing window frame without removing the wing window frame? This is the piece that the front of the door glass slides in. Maybe take the window out and slide it in??
Re: "Felt" replacement in wing window frame '70 B-Body [Re: VITC_GTX] #1230776
05/11/12 01:48 AM
05/11/12 01:48 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks.
Re: "Felt" replacement in wing window frame '70 B-Body [Re: VITC_GTX] #1230777
05/11/12 04:52 AM
05/11/12 04:52 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Yes. Disassemble the guts of the glass so you can remove it from the top of the door. Tape edges, take enough stuff off so that it doesn't get stuck on the way out.. including window felts/seals etc. You will need to unscrew the small phillips screw holding the rubber seal to the top of the vent window frame. Remove it and then remove the screw holding the rear leg (slider) of the vent wing window to the rest of the frame (at very top). Look in there, you'll see what I am talking about. At this point you should be able to separate the vent window slider leg enough to slide the window out from the top. Loosen things up as necessary to allow things to move around.
Re: "Felt" replacement in wing window frame '70 B-Body [Re: 70mopes] #1230778
05/11/12 12:20 PM
05/11/12 12:20 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks! I'll give it a try.
