Timing a 273 #1230575
05/09/12 07:42 PM
05/09/12 07:42 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Do you set the timing on a 273 the same as a 318? The 273 has the high compression pistons and a solid lift cam. Thanks
Re: Timing a 273 [Re: bobs69] #1230576
05/09/12 10:32 PM
05/09/12 10:32 PM
From my 1967 "Glenns". '67 4bbl 273 without CAP 10BTDC. With 5 ATDC. It's showing dual points on the non CAP application. CAP is Cleaner air package. No way I'd time an eng at 5 after
Re: Timing a 273 [Re: RapidRobert] #1230577
05/09/12 11:29 PM
05/09/12 11:29 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I would time it at what makes it run best within the constraints of the parts that are installed. I agree with the above, I would NEVER set an engine at 5 after as with the above mentioned emissions band-aid.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
