Dumb question, timing sprockets
#1230514
05/09/12 05:49 PM
05/09/12 05:49 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Any difference in timing sprockets between sets that use double NON-roller chains, and sets that use true roller chains?
b/rb application if it matters
If no answer no big deal, I will just order some parts and look...just wondered if anyone knew offhand
thx
Rich H.
Esse Quam Videri
Re: Dumb question, timing sprockets
[Re: Stanton]
#1230516
05/09/12 07:43 PM
05/09/12 07:43 PM
ZIPPY
S.E. Michigan
I was afraid someone would answer with that Yes, good explanation. That is of course correct and I'm well aware of that, however there is more than one type of "double roller" (which is a strictly a marketing term) chain. There is one type that usually has seams on the tiny cylinder shaped areas that physically sit between the teeth, which do not roll at all even though they are marketed as "roller". Should be called "double row" instead, because nothing actually rolls. Then there is the other type that has usually seamless tiny cylinder shaped areas that sit between the teeth, that actually DO roll. Those are correctly marketed as "roller", usually "true" on top of that but not always. The question is, are the sprockets the same between the two types of double row chains? Might be too basic to bother with, but maybe not.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1230517
05/09/12 08:20 PM
05/09/12 08:20 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I am not sure, as to the Mopar. I would think there is a difference, as on Chebbys, I know there is. I have always used the "true" roller double chains...but a few weeks ago,,had a 'low budget' dirt racer bring me a coffee can of crank/cam gears and a 'new' chain..?? NOTHING matched...I supplied a new "true roller" chain AND gears, degreed the cam for him and guess what,,everything is fine now. He couldn't believe it,,when he used all the other stuff and "lined up the dots" he had valve/piston clearance problems,,bent all the exhaust valves...??? Wonder just how far it was off..
If you like drag racing, support your local track.
[Re: ZIPPY]
#1230518
05/09/12 11:08 PM
05/09/12 11:08 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
They will physically look the same. As to whether one chain will fit the other is anyone's guess.
[Re: ZIPPY]
#1230521
05/16/12 11:40 AM
05/16/12 11:40 AM
ZIPPY
S.E. Michigan
I just ordered some. They're similar, same number of teeth, teeth are shaped the same, etc. The big difference is the width of the teeth. The roller style has wider/thicker teeth, wide enough to where they will not fit on the non-roller chain. On the other hand, the thinner tooth non-roller gears could "potentially" be used on the roller chain but probably not a good idea.
Rich H.
Esse Quam Videri
[Re: dodgeboy11]
#1230523
05/16/12 02:05 PM
05/16/12 02:05 PM
ZIPPY
S.E. Michigan
If there's any interest I can put a caliper on the links and post pics. Just let me know. Eyeballing it, I believe there may be a slight difference in the links, nothing tremendous though, because the teeth in the non-roller are actually longer than they need to be. What I wanted to do was lay the sprockets flat on top of each other, and sight them, so I did it that way. Can't see any huge difference in the teeth from that viewpoint. But viewing the parts from the side...the roller sprocket teeth are twice as wide (or more) than non-roller. The roller sprocket, won't even come close to fitting in the double non-roller chain. But, the non-roller sprocket does fit into the roller chain very nicely. I tend to get hung up on little details like that, once in awhile something like that will pay off....but in this case? Probably a waste of time True roller is better and there's not really app. that would not benefit from that, rather than non-roller. Going one step further: Could always degree a camshaft with the non-roller sprockets, and both types of chains.... but I probably won't go there. I just wish the whole aftermarket industry would resolve the "double roller" vs "true roller" vs "true double roller" marketing thing because it is very misleading. A guy just starting out does not understand what he's getting. Another thing? "Billet steel gears!". More marketing..... Even an OEM stock single chain timing set has a steel crank gear. As for the cam gear? I have a Direct Connection timing set from 1987 with an iron cam gear that I ran for 14 seasons....the car was was driven daily for a few years too not just a hot rod, the chain is quite stretched out.....but guess how much wear is on the iron cam gear? Practically nothing. Needless to say I'm developing a few opinions based off of this stuff, on the type of engine I tend to mess with
Rich H.
Esse Quam Videri
[Re: AndyF]
#1230525
05/16/12 04:53 PM
05/16/12 04:53 PM
Posts: 5,875 communist bloc of new jersey
jamesc
Another factor is that there really aren't many vendors for these parts. So a bunch of the timing sets on the market are actually just reboxed parts. Some vendors get aggressive with their "marketing", but when you open the box you see the same exact parts that others sell with less hype.
same as with a lot of other parts
[Re: AndyF]
#1230526
05/16/12 05:44 PM
05/16/12 05:44 PM
ZIPPY
S.E. Michigan
Yeah, checking out the Cloyes "street" vs the Comp "super high tech" was entertaining.
It's odd, though, that the mail order places will sell a comp service chain for that set, but not a cloyes service chain to be found even though it's the same darned thing.
I'm thinking timing chains are alot like flat lifters.
The old Direct Connection cam gear had a pentastar, a casting date, and an old 7 digit number cast into it...so it did have that going for it, and it kind of stands out in the crowd....
Rich H.
Esse Quam Videri
