318 poly top end gasket sets #1230498
05/09/12 05:09 PM
05/09/12 05:09 PM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
Not having any luck with local parts stores what is a good source to purchase these?
One day I will have something cool here.
Re: 318 poly top end gasket sets [Re: sdaurity] #1230499
05/09/12 06:15 PM
05/09/12 06:15 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I punched a 66 Coronet with a 318 into Summit's search engine and came up with this http://www.summitracing.com/parts/SLP-260-1571/ .
That 260-1571 is probably the Sealed Power part# so you could try that at the local parts store or just order it from Summit.
Kevin
Re: 318 poly top end gasket sets [Re: Twostick] #1230500
05/09/12 09:04 PM
05/09/12 09:04 PM
dogdays Offline
dogdays  Offline
Fel-Pro HS7734PT is the head set.
http://www.rockauto.com/catalog/moreinfo.php?pk=124126
will show you what it looks like.
R.
Re: 318 poly top end gasket sets [Re: sdaurity] #1230501
05/10/12 09:15 AM
05/10/12 09:15 AM
crlush Offline
crlush  Offline
Ordered mine thru oriely, just took a competent worker.
Re: 318 poly top end gasket sets [Re: crlush] #1230502
05/10/12 09:23 AM
05/10/12 09:23 AM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
Thanks guys.
