Heater Box Housing Paint...Resto UPDATE ???s #123029
09/19/08 09:51 AM
09/19/08 09:51 AM
Tenn.
jrwoodjoe Offline OP
Tenn.
My next project for the Challenger is the restoration of the Heater Box (non A/C car). I know YO sells a "kit" to paint the housing and I imagine that Eastwood does also.
Should I use one of those or is there a less expensive route? Car is not a All out show car but will be a REALLY nice occasional Driver.
Thanks, Joe
65 Barracuda
70 Challenger
Re: Heater Box Housing Paint...What should I use? [Re: jrwoodjoe] #123030
09/19/08 10:24 AM
09/19/08 10:24 AM
None
71rm23 Offline
71rm23  Offline
None
I'm doing mine right now. Its a '71 B-Body box with A/C. I took mine apart, took it to the bath tub and gave it a bath. Then after its dried, I used a "clear" paint to brighten it up. No color or anything, just clear.
Re: Heater Box Housing Paint...What should I use? [Re: 71rm23] #123031
09/19/08 12:38 PM
09/19/08 12:38 PM
Hummelstown, PA
AINTNRT Offline
AINTNRT  Offline
Hummelstown, PA
Did the same thing to both my heater boxes. May not be 100% correct but looks good.
Re: Heater Box Housing Paint...What should I use? [Re: AINTNRT] #123032
09/19/08 01:18 PM
09/19/08 01:18 PM
Silicon valley
A12bee Offline
super street
A12bee  Offline
super street
Silicon valley
I got this kit to redo the air grabber hoods I have for my 70 RR. I did a friends heater box on his 67 GTO and it came out really nice. May want to look into this stuff. Easy to use, at least it was for me.
http://www.restorationfullcircle.com/
This space left intentianlly blank.
Re: Heater Box Housing Paint...What should I use? [Re: A12bee] #123033
09/19/08 01:31 PM
09/19/08 01:31 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I painted mine and when I used the heater the paint bubbled and peeled.
Re: Heater Box Housing Paint...What should I use? [Re: mopars4ever] #123034
09/19/08 01:36 PM
09/19/08 01:36 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
No paint needed.
If you can media blast it that works very well.
Afterwards apply a coat of satin clear and it will
look brand new.
You can also just wash it thoroughly and clear coat it.
Jules
Re: Heater Box Housing Paint...What should I use? [Re: jrwoodjoe] #123035
09/19/08 01:53 PM
09/19/08 01:53 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I just pressure washed mine clean, no clear to flake off. My car is a driver.
A different box I did with a pressure washer.It was before I knew about 71TA gaskets. Made my own.
Re: Heater Box Housing Paint...What should I use? [Re: JulesdaWiperman] #123036
09/19/08 01:59 PM
09/19/08 01:59 PM
cataclysm80 Offline
cataclysm80  Offline
I'm curious, what type of media do you recommend blasting with Jules?
Tav
Re: Heater Box Housing Paint...What should I use? [Re: cataclysm80] #123037
09/19/08 02:11 PM
09/19/08 02:11 PM
Tenn.
Tenn.
Thanks for the tips everyone. I think that I will powerwash it as Gary suggested and then clear it as others suggested. The box is in good shape so it may look fine doing that. If not, then I will try media blasting it.
Jules, if I had the budget for it...I would be sending anything to you that you could do. You do awesome work and are a great member of this board. Thanks for the advice.
I've got one of Jim Filmore's gasket kits for it and a new heater core. A tried to buy a new blower motor but the ones I found looked nothing like the original. A friend of mine says he has one he bought a while back that is like the original and is sending it to me. I'll post pics of it when it's done.
Thanks, Joe
Re: Heater Box Housing Paint...What should I use? [Re: cataclysm80] #123038
09/19/08 02:13 PM
09/19/08 02:13 PM
Tenn.
Tenn.
Tav
I would think Bead. Am I right Jules? Joe
Re: Heater Box Housing Paint...What should I use? [Re: JulesdaWiperman] #123039
09/19/08 06:03 PM
09/19/08 06:03 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
No paint needed.
look brand new.
I have done them this way for a few years now.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Heater Box Housing Paint...What should I use? [Re: Troy] #123040
09/19/08 08:02 PM
09/19/08 08:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I use a mild acid solution used by detailers to remove brake dust off wheels.. Works extremely well, don't need to clear coat cause it shines without it...
Re: Heater Box Housing Paint...What should I use? [Re: 1_WILD_RT] #123041
09/19/08 08:08 PM
09/19/08 08:08 PM
Cincinnati, Ohio
Cincinnati, Ohio
I use something similar, it's called J-Shop made by SC Johnson. It's alkaline and some powerful stuff, But you don't want it anywhere near alunimun. Spray it on and pressure wash off. It makes tires look brand new with out any dressing. Works good for these kinds of cleaning jobs.
Re: Heater Box Housing Paint...What should I use? [Re: Challenger 1] #123042
09/19/08 10:31 PM
09/19/08 10:31 PM
super gas
super gas
cataclysm80 ,
I use MIL-30 glass bead. It's like flour. It will clean without damaging the surface.
It will just scuff it enough so that the thin clear film I put on will not flake off.
The other methods are just as good.
Jules
Re: Heater Box Housing Paint...What should I use? [Re: jrwoodjoe] #123043
09/20/08 01:01 PM
09/20/08 01:01 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
I haven't tried this on mine yet, but if you check a thread I started on Ramcharger airbox resto's the same material I used to rejuvenate the orange fiber-stuff used on those items I suspect will work for the black heater box material. It's Watco Danish Oil finish and it's a 'top coat' for wood surfaces. It is called an "oil" but once it is applied it dries to the touch, and of course it beautifies wood and brings the grain out...just happens to also beautify Ramcharger Airboxes.
Here's a link to that old thread.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Heater Box Housing Paint...What should I use? [Re: JulesdaWiperman] #123044
09/21/08 03:22 AM
09/21/08 03:22 AM
People's Republic of Kali
70runner Offline
70runner  Offline
cataclysm80 ,
Jules
Jules, what is the bead size for "MIL-30"? I usually use MIL-8 which is a bead size of .006-.008in diam.
Re: Heater Box Housing Paint...What should I use? [Re: 70runner] #123045
09/25/08 02:51 PM
09/25/08 02:51 PM
Tenn.
Tenn.
OK guys,
Heater box has been taken completely apart and the pieces are in pretty good shape overall. You can see in the pic that the heater core had a leak but I have a new one. I'm also in the process of getting a new blower motor.
The only item that I have not removed is this flap. To remove it, I will need to drill out the rivets for the bracket that holds it..correct? If so, who sells these type rivets? Jules..can I buy them from you if needed?
Thanks, Joe
Re: Heater Box Housing Paint...What should I use? [Re: jrwoodjoe] #123046
09/25/08 04:55 PM
09/25/08 04:55 PM
why do you need to take it out. i just did my box and left it in. I sandblasted the plates using cardboard to block the fiberglass body from the sand and then primed and paint the plate (using more cardboard to block the overspray.
then I glues new foam in that I got from some packages down in the shipping department and cut it to size and glued in with 3m pray adhesive (super 77 I believe).
Looks great
Re: Heater Box Housing Paint...What should I use? [Re: Troy] #123047
09/26/08 02:30 AM
09/26/08 02:30 AM
phx
metalgod Offline
metalgod  Offline
phx
they are not too hard to do
Re: Heater Box Housing Paint...What should I use? #123048
09/26/08 09:30 AM
09/26/08 09:30 AM
Tenn.
Tenn.
This foam is in very bad shape and I want to replace it while I have it apart.
You guys are right, it is a pretty simple unit (mine being a HEATER ONLY box makes it more so). I bought one of Jim's (moparts member 71TA) gasket resto kits for it. I opened up what he sent me after I had torn into the box and was glad to see that some things that I figured weren't included were. It's a nice kit. Mopar Muscle recently did an article on Heater Box Resto and the person doing it got a few gaskets from YO and then cut the foam pieces for the rest. After seeing Jim's kit, can't believe they did not mention it in the article.
Joe
