1966 Charger Head light motors #1230130
05/09/12 05:32 AM
05/09/12 05:32 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Who or where is the best place to go for information about fixing my headlight motors?
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: 1966 Charger Head light motors [Re: 19cuda73] #1230131
05/09/12 06:14 AM
05/09/12 06:14 AM
places
79powerwagon Offline
places
Headlight Motor Man (on Facebook) is the guy! His name is Topher on here, though he doesn't post much, and he's on the 66-67chargerornocar.com site. He did mine BEAUTIFULLY, and I recommend him HIGHLY!!!
Topher McGillis (I do hope I have that right, as it has been a few years) is a heck of a great asset to the hobby!
Re: 1966 Charger Head light motors [Re: 79powerwagon] #1230132
05/09/12 06:45 AM
05/09/12 06:45 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Re: 1966 Charger Head light motors [Re: 19cuda73] #1230133
05/09/12 10:06 AM
05/09/12 10:06 AM
New Jersey
Craig Offline
Craig  Offline
New Jersey
Not to take anything away from Topher or anyone that rebuilds the motors, but the issue may not be the motor, but the relays. This is a trick I learned on the 66 Charger forum. The old stock relays way up under the dash may not be flowing enough current anymore, the motors draw a lot. On my 66 Charger, all I had to do was add a couple of new Bosch relays that take the motor power and use it as the relay switching power. The new relays are hidden in the left fenderwell and have a fused, good short power connection to the battery and go straight to the motors. So the original relays are now just switching on the new relays. This way you don't have to pull the dash to get to the old ones. Even if your motors do need to be rebuilt you still may have the weak relay output.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: 1966 Charger Head light motors [Re: bobs66440] #1230134
05/09/12 12:39 PM
05/09/12 12:39 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
He does great work!
http://headlightmotorman.web.officelive.com/default.aspx
Another vote for Topher!! He's done the ones for the late B Magnum headlight door motor as well. Great guy!!
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
