Testing fuel pump on '93 Caravan........... #1229837
05/08/12 09:27 PM
05/08/12 09:27 PM
Between Houston & Galveston TX
SattyNoCar Offline OP
Is there any way to jump a connection/terminal underhood of a '93 Caravan to test the fuel pump?
Been chasing a 'no start' issue. Yesterday, I could clearly hear the fuel pump kick on, when I'd cycle the key, now, silence.
I'm at a loss trying to diagnose this thing, and having a generic haynes manual isn't helping.
Or, am I missing something else?
John
Re: Testing fuel pump on '93 Caravan........... [Re: SattyNoCar] #1229838
05/09/12 12:23 AM
05/09/12 12:23 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Dude you've gotta get rid of this thing already...
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Testing fuel pump on '93 Caravan........... [Re: SattyNoCar] #1229839
05/09/12 08:08 AM
05/09/12 08:08 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Find the ASD and fuel pump relays.Then have someone cycle the key.They should click.Listen at the fuel inlet also when cycling the key.Best way is ckecking with a fuel pressure gauge.The relay can be swapped as they use mostly the same relays in the box.Also try smacking the tank with a rubber hammer as someone cranks it.Most times if the pump isnt totally gone the shock will get it going.Rocky
Chrysler Firepower
Re: Testing fuel pump on '93 Caravan........... [Re: therocks] #1229840
05/09/12 07:23 PM
05/09/12 07:23 PM
I disconnected the battery to 'reset' the computer, the fuel pump works again.
I'm not getting any spark.
Going out to check wiring.
The problem I'm having is that I can test wires all day with my dvom, but, unless its something obvious, I don't know what I'm looking at.
Yeah, I know I should get rid of it, but, I paid $200 for it 34K miles ago, and the only time it gives me fits is when I have to jack with it to try to pass emissions. For all the posts I've had on here about this van, I still have less then $900 into it, including the purchase price. I've paid a LOT more for heaps that were much worse.
John
