Re: 727 or TH400? Opinions please
[Re: Bubba]
#1229477
05/08/12 09:12 PM
05/08/12 09:12 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
727 with a 1" midplate allowing you to use better converters
Tranzact clean neutral transbrake
Billet front planetary
300M output shaft.
Alluminum 5 disk drum or you could sacrifice with weight and run a billet steel drum just do not run the stock drum.
The normal little tricks on any basic 727 race tranny ussually included with the paperwork for the Valve body. If you know someone familiar with these they are easy to build. It can be done for less than $3,000. Or you can pay a known high profile torqueflite guy $7,000.
If you run the straight cut planets it will cost a lot more due to the price of those gearsets. This is where the T400 is cheaper plus you can get a case that is already certified with no need to run a sheild.
Leon
