Protecting shift cable from direct contact w/ header...
#1229411
05/08/12 11:40 AM
05/08/12 11:40 AM
Posts: 8,680 Buford, GA
I_bleed_MOPAR
Buford, GA
Melted cable. BB w/ Hedman Hedders, B&M Pro Ratchet. Tube is very, very close to cable bracket on pan. Will one of the slip-on sleeves protect it if it slips again and comes into direct contact for a while? Would a longer cable (6-8-10 ) help with routing? I know the best thing to do would be to bite the bullet and buy a different shifter that shifts from the back but trying to work with what we have. TIA Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: Protecting shift cable from direct contact w/ header...
[Re: bill440rt]
#1229415
05/10/12 09:16 AM
05/10/12 09:16 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Run the cable through a length of heater hose and tie it away from the header..
I am truckless..
[Re: 63stabamatic]
#1229416
05/10/12 10:00 AM
05/10/12 10:00 AM
Andrewh
http://www.extremeheatprotection.com/this stuff should have something for you. I use the fire sleeve myself. only good for 500 F continuous, but I only expect incedental contact.
