Re: Wiring Harness Mod? MCG
[Re: dart4forte]
#122930
09/21/08 04:21 PM
09/21/08 04:21 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Looking at the pics I don't see anything for $90 that can't be homemade for $20.
[Re: John_Kunkel]
#122931
09/21/08 04:44 PM
09/21/08 04:44 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
That bypasses the amp gauge with a large wire (likely 8 ga) and likely relays something else in the system such as the ignition/voltage regulator wire.
So, to pull this off yourself, you'll need: 8 ga wire 12 ga fuse link for charging wire
I don't think you need to relay the ign but I do suggest relaying the headlights.
My car has the original charging wire connected to the starter relay as well for a double current path to the dash. I also relayed and spliced my headlights as in the first diagram (I only used 1 fuse holder since both circuits don't run simultaneously on a Duster) and my headlights are a lot brighter...running a square back alternator that is either 65 or 78 amps. I just added a volt gauge and everything in the car works much better now.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: John_Kunkel]
#122932
09/21/08 06:13 PM
09/21/08 06:13 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
I'm sure you are right but right now time is more important. It's the little things on my project that are eating me up.A kit for me at this point would be ideal. Plug n Play.
