Torque Converter Identification #1229103
05/07/12 10:10 PM
05/07/12 10:10 PM
Washington
fish59 Offline OP
fish59  Offline OP
Washington
I have a 1966 transition and a 1977 440. I found out after the fact that I needed to use the torque converter from the 1977 due to balancing issues. I really don’t remember which torque converter that I used since I put it in and it has sat for years.
I pulled the torque converter this afternoon and it is marked with the numbers "7062" or "7962" (I can’t make out the second number very well).
I can’t find any other marks on the torque converter. Is this enough information to identify the year of the torque converter?
Re: Torque Converter Identification [Re: fish59] #1229104
05/07/12 11:37 PM
05/07/12 11:37 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
can you poast some pictures front and back may help?
Re: Torque Converter Identification [Re: calrobb2000] #1229105
05/08/12 12:22 AM
05/08/12 12:22 AM
Washington
fish59 Offline OP
fish59  Offline OP
Washington
Please see the attached picture...
Re: Torque Converter Identification [Re: fish59] #1229106
05/08/12 12:35 AM
05/08/12 12:35 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
from what i see , no weights on front of convertor means early piece not balanced for any newer than 73last year for steel crank most cases .low stall app 1800rpm !
do you have a steel or cast crank ? show us a pic of the harmnic balancer ?
Re: Torque Converter Identification [Re: calrobb2000] #1229107
05/08/12 12:58 AM
05/08/12 12:58 AM
Washington
fish59 Offline OP
fish59  Offline OP
Washington
I have a 1966 Chrysler Newport Convertible. I removed the original 383 and installed a 440 from a 1977 Chrysler Newyorker. I am not sure which torque converter I used. The 1977 440 would have a cast crank shaft.
Please see the attached picture of the harmonic balancer.
Thank you for your help.
Re: Torque Converter Identification [Re: fish59] #1229108
05/08/12 01:19 PM
05/08/12 01:19 PM
Nova Scotia Canada B2Y 1E4
SANDYinNS Canada Offline
There should be weights on either side of the drain plug . That pic is also a narrow ring gear low stall............ look for a wider ring gear(smaller converter. Most late 440's have the wider ring gear ( higher stall) converter in them.
Sandy in Nova Scotia formerly drdodge340
68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute
-76 feather duster-76 duster-77 street van
- 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
