70 challenger proportioning valve same 4 DISC and DRUM? #1228137
05/06/12 08:59 PM
05/06/12 08:59 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
anyone know for sure? thanks dan
Re: 70 challenger proportioning valve same 4 DISC and DRUM? [Re: ph23vo] #1228138
05/06/12 09:25 PM
05/06/12 09:25 PM
not certain about 70 but I know for my 69 charger it is the same prop/ distribution block that takes the 2 lines from the master cyl and distributes it to each wheels.
Re: 70 challenger proportioning valve same 4 DISC and DRUM? [Re: ph23vo] #1228139
05/06/12 09:58 PM
05/06/12 09:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'm assuming your talking about the main distrubution block,...I'd like to say yes, but not 100% sure, IIRC the addition of the PV on disc equipped cars is the only difference in DB vs PV operation on the early set ups
Re: 70 challenger proportioning valve same 4 DISC and DRUM? [Re: ph23vo] #1228140
05/06/12 10:11 PM
05/06/12 10:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
....here's the drum and disc comparison factory print of the DB and PV set up
Re: 70 challenger proportioning valve same 4 DISC and DRUM? [Re: ] #1228141
05/06/12 10:23 PM
05/06/12 10:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Correct on the 69 and down set ups using the same distribution blocks whether the car was disc or drum, disc cars would have a seperate PV or residual pressure valve located in the rear line
Re: 70 challenger proportioning valve same 4 DISC and DRUM? [Re: DAYCLONA] #1228142
05/06/12 10:57 PM
05/06/12 10:57 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
I'm assuming your talking about the main distribution block,...I'd like to say yes, but not 100% sure, IIRC the addition of the PV on disc equipped cars is the only difference in DB vs PV operation on the early set ups
then the add of the PV would be all i need then..A66 car.. had drums up front bought an entire rebuilt front end with new everything off Cl for 100.00! so i,m adding disc to it now... thanks for the pictures! dan
