Re: 70 challenger proportioning valve same 4 DISC and DRUM?
[Re: ph23vo]
#1228138
05/06/12 09:25 PM
05/06/12 09:25 PM
not certain about 70 but I know for my 69 charger it is the same prop/ distribution block that takes the 2 lines from the master cyl and distributes it to each wheels.
[Re: ph23vo]
#1228139
05/06/12 09:58 PM
05/06/12 09:58 PM
Posts: 18,157 Mass
DAYCLONA
Mass
anyone know for sure? thanks dan
I'm assuming your talking about the main distrubution block,...I'd like to say yes, but not 100% sure, IIRC the addition of the PV on disc equipped cars is the only difference in DB vs PV operation on the early set ups
[Re: ]
#1228141
05/06/12 10:23 PM
05/06/12 10:23 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Correct on the 69 and down set ups using the same distribution blocks whether the car was disc or drum, disc cars would have a seperate PV or residual pressure valve located in the rear line
[Re: DAYCLONA]
#1228142
05/06/12 10:57 PM
05/06/12 10:57 PM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
I'm assuming your talking about the main distribution block,...I'd like to say yes, but not 100% sure, IIRC the addition of the PV on disc equipped cars is the only difference in DB vs PV operation on the early set ups
then the add of the PV would be all i need then..A66 car.. had drums up front bought an entire rebuilt front end with new everything off Cl for 100.00! so i,m adding disc to it now... thanks for the pictures! dan
