WHAT THE HECK IS THIS? Electrical 70 duster
#1228052
05/06/12 05:48 PM
05/06/12 05:48 PM
Posts: 254 PA
MrMopar95
Panhandler
Panhandler
PA
this is plugged in under the dash of my 1970 plymouth duster and is hot all the time when key is off, its a 3 prong end little aluminum canister, i cannot find it on the wiring diagram so far, not sure what it even is?
Does anyone know what this is?
Nick Bowman 1970 Plymouth Duster - "Footbrake" Red-or-Dead 2X Pittsburgh Raceway Park Points Champion
Re: WHAT THE HECK IS THIS? Electrical 70 duster
[Re: MrMopar95]
#1228053
05/06/12 05:51 PM
05/06/12 05:51 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I think its for dash lighting...I think I had one on my 70 Charger...bolted in the steering column....there was a angular tube that would put a focused light on the ignition where you put the key...
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1228054
05/06/12 05:52 PM
05/06/12 05:52 PM
Pyper70
Athens, Greece
and I think it activates when a door is open...so if your door is open and the key is off, that would be why its hot
[Re: GreenGlow]
#1228056
05/06/12 06:10 PM
05/06/12 06:10 PM
Posts: 254 PA
MrMopar95
Panhandler
Panhandler
PA
thank you yes door closed the piece did not get hot, ok thats for that, I HAVE POWER TO MY TURN SIGNALS,RADIO,HEATER FAN,WIPER ALL WORK WITH KEY OFF NOT IN IGNITION???
[Re: mikemee1331]
#1228058
05/06/12 06:41 PM
05/06/12 06:41 PM
Posts: 254 PA
MrMopar95
Panhandler
Panhandler
PA
messed with the key a few times, they dont work with key off now...
