904 Transmission #1228028
05/06/12 03:01 PM
05/06/12 03:01 PM
Easton, Kansas
Moparmedic440 Offline OP
Easton, Kansas
I just rebuilt a 904. I attempted to air test the clutchs. When I applied the air i have a hugh air leak and no clutch activation. The sealing rings on the front pump are new. The gasket between the housing looks to be a poor fit. Is there a difference in front pumps in the early 70s. Are there a difference in gaskets. Thanks for any help.
Re: 904 Transmission [Re: Moparmedic440] #1228029
05/06/12 04:47 PM
05/06/12 04:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pump-to-case gasket is the same from '60-on. There was a sealing ring change in '68 but if the rings fit the shaft they're probably correct. If you installed a later pump with an earlier input shaft the bore diameter is larger and the smaller sealing rings won't seal.
Do you have for/aft end play on the input shaft? If not, it's possible that one of the clutch discs is misaligned and won't let the pump properly seat against the case.
