Help Wanted
We are looking for an experienced automotive machinist and mechanic. the person we are
seeking must have the ability to grind crankshafts, bore/ hone engine blocks, be well
versed in cylinder head rebuilding and repair (seats, guides, basic and performance valve jobs) of most all makes and models, surface grind
flywheels, align bore and deck engine blocks, rebuild connecting rods. balance rotating
assemblies, and perform general machining operations. CNC experience is preferred. experience with the following equipment is required
Rottler CNC block machining center
Rottler HP6A diamond cylinder hone
Rottler SG7 seat and guide machine
Hines Eliminator balance machine
Peterson flywheel grinder
Storm Vulcan crankshaft grinder
Sunnen rod hone
Bridgeport vertical mill
CNC operator experience for the block machining center is a must. you don't need to be able to program, just execute existing programs.
other duties may include tear down and inspection of engines, parts cleaning, etc.
engine building experience is a plus, but not essential.
we work in a well lighted climate controlled shop with a friendly atmosphere. if your a motivated individual, reliable and trustworthy, this could be a great opportunity for you.
all new hires must pass a routine physical and drug test.
please send your resume to;
performance only
1364 Gwenzell av.
suite H
Delray Beach, Fl. 33444
or
Email to
kscooter15@aol.com please use resume in the subject line.
Thank You...
