Ti valves
#1227926
05/06/12 08:19 AM
05/06/12 08:19 AM
Posts: 317 Indiana
79_W200
Indiana
Switching to ti vales on my -1 heads want opinions on hardened tip or run lash caps and what brands hold up
1979 W200 470
Re: Ti valves
[Re: 79_W200]
#1227927
05/06/12 08:53 AM
05/06/12 08:53 AM
Posts: 2,091 Delray beach, Florida
Performance Only
i run hard tips on all Ti. valves. we sell several brands and they all recommend hard tips as well. that way you have the option to run lash caps or not, depending on what your combo requires. there's very little difference in cost between the two choices.
machine shop owner and engine builder
Re: Ti valves
[Re: Performance Only]
#1227928
05/06/12 10:40 AM
05/06/12 10:40 AM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
I agree with Dan. We always run hard tips and lash caps.
Re: Ti valves
[Re: LA360]
#1227931
05/06/12 08:44 PM
05/06/12 08:44 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
run hardened tips and forget the lash caps. Why put another part in a engine that could go bad.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ti valves
[Re: bigtimeauto]
#1227932
05/06/12 09:28 PM
05/06/12 09:28 PM
Posts: 6,146 Melbourne , Australia
LA360
The hardened tips will result is a greater distance between the end of the valve and the lock groove, so factor that in when having your valves made. Most Ti valves are custom, so if you're not sure about valve head angles etc, perhaps order them through your engine builder as he can advise you which way to go.
Alan Jones
Re: Ti valves
[Re: 79_W200]
#1227933
05/07/12 11:29 AM
05/07/12 11:29 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
How much spring pressure and RPM are you talking about here? Useage of the vehicle?
RIP Monte Smith
Re: Ti valves
[Re: CompWedgeEngines]
#1227934
05/07/12 11:56 PM
05/07/12 11:56 PM
Posts: 317 Indiana
79_W200
Indiana
This is in a pulling truck. rpm 8000-8500 for 20-25 seconds a pass. T and D rockers,pac 1.5 series double springs, tool steel retainers moving to light wieght top end do to long high rpm
1979 W200 470
Re: Ti valves
[Re: 79_W200]
#1227936
05/08/12 01:48 AM
05/08/12 01:48 AM
Posts: 4,209 New York
polyspheric
New York
A lash cap can't be an afterthought, since it changes the rocker geometry.
Boffin Emeritus
