Need help with rad issue
#122766
09/18/08 08:57 PM
09/18/08 08:57 PM
Posts: 205 Edmonton Alberta, Canada
R3DART
I was mounting a trans cooler last night, slipped with the drill and nicked my rad core. It started leaking instantly so I drained it and pulled it. This morning I dropped it off at the local rad shop, get a phone call 2 hours later and they tell me they fixed the hole, but its leaking from about 5 different spots So I go down and take a look, and sure enough, it's leaking all over the place. So my question is, could it be that the rad had sat at one time and corroded, then when it went back into use the owner fixed it with bars leak , and when they pressured it up with air it pushed it out, or did they drop it and would this cause the problem.
Re: Need help with rad issue
[Re: R3DART]
#122767
09/18/08 08:59 PM
09/18/08 08:59 PM
Challenger 1
Cincinnati, Ohio
It's old, that all. Can they recore it?
[Re: R3DART]
#122771
09/18/08 11:21 PM
09/18/08 11:21 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
I would not blame the shop-I would thank them! They are doing their job.
Any repairs/and or inspections they do,they usually pressure test the rad-sometimes up to 25 pounds! This ensures no leaks,and if it leaks it will!! It's best to deal with it now rather than take it back and saying "ever since..."
Given the unknown history of the rad prior to you buying the car,looks can be decieving.Anybody can spray bomb an old rad,but what's going on inside it you can't see. Do it once do it right.Get it recored. The shops stand behind their work with good service and warranty.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: R3DART]
#122773
09/19/08 01:04 AM
09/19/08 01:04 AM
Posts: 6,516 Santa Cruz, California
Lefty
It could have been patched with stop leak or it may just be old and thin. Either way it's not the shops fault for it leaking after a cleaning. If they dropped it you would see the dent(s). Just recore core it and
