Can you use Factory Dog Dish hub caps w/3" wheel studs? #1227495
05/05/12 10:53 AM
05/05/12 10:53 AM
S.E. Conn
Hoof Hearted Offline OP
S.E. Conn
Well, Can ya?
Yes I have 3" studs on the car, No I don't have any Dog Dish Caps yet.
It's a 70 Charger, 15x7 and 15x8 Steel Wheels...
Thanks all
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Can you use Factory Dog Dish hub caps w/3" wheel studs? [Re: Hoof Hearted] #1227496
05/05/12 10:58 AM
05/05/12 10:58 AM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I had 3" studs on the back of my Duster and the dog dishes fit over them perfect!
Re: Can you use Factory Dog Dish hub caps w/3" wheel studs? [Re: Hoof Hearted] #1227497
05/05/12 11:18 AM
05/05/12 11:18 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Try it and see if they fit. If not, cut the studs down a little to allow the hub cap to fit.
There is NO requirement the car have 3" studs. The NHRA rule is the studs have to extend through the face of the wheel at least the diameter of the stud (with washer installed if used). So a 1/2" stud must have at least 1/2" exposed once the wheel and washer is on (before installing the lug nuts).
If you ONLY run the steel wheels, the stock studs are adequate for racing. The longer studs are needed when aftermarket wheels are used which have a thicker center section.
Scott
Re: Can you use Factory Dog Dish hub caps w/3" wheel studs? [Re: ProStDodge] #1227498
05/05/12 12:33 PM
05/05/12 12:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
They do on my '68 Roadrunner. That said, 3" studs are a PITA as far as removing & installing the rolling stock if the car has smaller wheel openings, so for steel wheel cars or where the excess length isn't needed, I like 2" studs.
I also prefer the dog-point ends to having the threads all the way to the tip; easier to start the nuts.
