Source for clutch return spring-67 barracuda 4 speed #1227488
05/05/12 09:56 AM
05/05/12 09:56 AM
Penna
70satelliteguy Offline OP
Penna
I am looking for the return spring. My clutch will not return back out without some help. It broke and we shortened it and reinstalled but it is now not strong enough!
Thanks Mike
Re: Source for clutch return spring-67 barracuda 4 speed [Re: 70satelliteguy] #1227489
05/05/12 10:12 AM
05/05/12 10:12 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Try Brewers they advertise on this site , Great people to work with!!!
Re: Source for clutch return spring-67 barracuda 4 speed [Re: hemirdrnnr] #1227490
05/05/12 11:16 AM
05/05/12 11:16 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Centerforce clutch?
I thought people just removed the pedel return springs altogether to fix that??
Re: Source for clutch return spring-67 barracuda 4 speed [Re: 70satelliteguy] #1227491
05/05/12 04:44 PM
05/05/12 04:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There are two springs, the one at the pedal and the one at the throwout fork...which do you need?
Re: Source for clutch return spring-67 barracuda 4 speed [Re: John_Kunkel] #1227492
05/06/12 06:09 PM
05/06/12 06:09 PM
Penna
Penna
Thanks for the replys !
"There are two springs, the one at the pedal and the one at the throwout fork...which do you need? "
I need the one at the throwout fork but it would not be a bad idea to replace both of them!
Mike
Re: Source for clutch return spring-67 barracuda 4 speed [Re: 70satelliteguy] #1227493
05/07/12 12:46 PM
05/07/12 12:46 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
http://brewersperformance.com/proddetail.asp?prod=FS480
Here is the fork spring. You need to remove the spring under the dash when using a diaphragm clutch and no pedal stop. It works as an assist spring not a return spring.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Source for clutch return spring-67 barracuda 4 speed [Re: 70satelliteguy] #1227494
05/07/12 05:54 PM
05/07/12 05:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Keep in mind that if your pedal free travel is excessive the overcenter spring will prevent the pedal from fully returning...even if the fork spring is good.
