1968 C body question #1227037
05/04/12 12:37 AM
05/04/12 12:37 AM
CENTRAL MINN
1965_PLYMOUTH Offline OP
CENTRAL MINN
I have a guy looking for a shroud for a 1968 Plymouth Sport Fury 383 4 barrel with A/C. I have a 1968 Polara 2 door hardtop with a 383 4 barrel with A/C. my shroud number is 2785435 in the Dodge and his original number in the Plymouth is 2785479. is it likely that Dodge and Plymouth use different part numbers? we both have the radiator part number 2898061. both cars have clutch fans. otherwise, does anyone know which shroud number would be correct? both?
Re: 1968 C body question [Re: 1965_PLYMOUTH] #1227038
05/04/12 12:39 AM
05/04/12 12:39 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Does his car have a larger diameter fan?
- Stu Harmon
Re: 1968 C body question [Re: feets] #1227039
05/04/12 12:48 AM
05/04/12 12:48 AM
CENTRAL MINN
CENTRAL MINN
we did not measure our fans, but I was assuming since both car's had factory A/C with 383 4 barrels, we both had the 2863216 clutch fans. maybe that's the next question I will ask him. they should both have "white" inked stamped part numbers.
Re: 1968 C body question [Re: 1965_PLYMOUTH] #1227040
05/04/12 09:04 AM
05/04/12 09:04 AM
Westfield, MA
rbrogle Offline
super street
rbrogle  Offline
super street
Westfield, MA
It should be a 2785435. I can't say I'ver ever seen a "79" shroud anywhere. Sounds like another case of "never say never" with Ma Mopar.
Rob '70 Fury III 'vert (GT Clone)was 318 3 on the tree,now 440 automatic '68 300 2 Door HT vinyl/cloth bench '68 Newport Custom 4 Dr. HT, 383/2, FULLY LOADED! '68 New Yorker 4 Door HT, 440/Auto, loaded! 2004 Chrysler 300M Special daily driver
