Re: tires tires tires
[Re: mickm]
#1227004
05/04/12 12:38 AM
05/04/12 12:38 AM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
A narrow wheel is probably not your best answer. BFG suggests a wheel between 8" and 10.5" wide. They made their measurements on a 9.5" wheel. I'd take that as a strong suggestion. The 10" wheel is a better fit than the 8" wheel. The tire will still be a foot wide but you want a wide tire.
[Re: feets]
#1227005
05/04/12 12:55 AM
05/04/12 12:55 AM
Posts: 120 Vancouver,Canada
70 Roadrunner*
Vancouver,Canada
I'm running a 295-50-15 tire on an 8.5 rim with my 70 RR...Tried the exact same tire with a 10 rim and no joy. The 8.5/295 combo fits really nice... Dave
[Re: 70 Roadrunner*]
#1227009
05/04/12 02:34 AM
05/04/12 02:34 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The rear wheels have 6.0" of back spacing... The wheels are mine & intended for my Coronet R/T Vert... The car in the picture is my buddies & we just bolted them up to check clearances... Everything clears with .5" or more of clearance... I'll know more when I bolt them on my car... But a 68-69 Coronet has a slightly bigger (wider) wheel well than a 70 Roadrunner. BTW The change from 14" steelies completely changes the look of my buddies Coronet..
#1227010
05/04/12 02:34 AM
05/04/12 02:34 AM
Posts: 4,179 California
mickm
California
feets has a good point thought. 8.5 isn't too bad, while 8 may not be so good. what is th backspacing on that?
but the real question is, is it really worth it to buy a whole new set of rims to get .9 inch more tire under there?
[Re: radar]
#1227012
05/04/12 12:30 PM
05/04/12 12:30 PM
mickm
California
Why not grab two et streets or something? A stickier tire might be more fun to drive. I wouldn't spend the dough on such a small upgrade especially if its a compromise with the 8.5" rim.
that's what i'm going to do. and i just found that they only make a 295/50, not a 60. i like the height and stance that the 275/60 gives the car, so it looks like i'll just go for a set of those.
i need more traction, and will need even more once the new engine is done!
